No offence but if that was true then HKS/Blitz/etc wouldn't sell after market turbo timers would they?![]()
I just drive off boost the last half mile or so then give it 30 seconds to a minute to cool down.
143k on original turbo with a remap on for 40k and it's fine still.
Turbochargers are driven by exhaust energy.
Part of that energy is heat.
You don't create boost at idle and consequently you don't create as much heat
coolant and oil temp never get hotter at idle![]()
I think we can safely say if the car is stock then you can get in, drive, get out worry free.
IF the car has been modified, ie its running more boost than stock then you should let it cool down a bit before you switch it off, driving the last mile of your journey off boost is sufficient in my mind, decent oil is also a good idea.
I never bother waiting - just turn it straight off. Given it's only a stock 2 litre (320D), I'm not too concerned.
I warm up and down before pushing my little 1.6 turbo powered gremlin.
