My new gaming pc
13 Mar 2011
Hi there, im building a new pc, i already have the i5k chip, i would like your thoughts and recommendations, this is what i've put together so far.
Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey £683.99
(£569.99) £683.99
(£569.99)
Sapphire ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card £575.99
(£479.99) £575.99
(£479.99)
Intel 510 Series "Elmcrest" 250GB 2.5" SATA-3 Solid State Hard Drive with FREE Shogun 2 Game £449.99
(£374.99) £449.99
(£374.99)
Coolermaster RC-1000 Cosmos PURE Black Silent Full Tower Case - All Black £179.99
(£149.99) £179.99
(£149.99)
Microsoft Windows 7 Ultimate 64-Bit - OEM (GLC-00736) £149.99
(£124.99) £149.99
(£124.99)
Corsair Professional Series™ Gold AX750 High Performance 750W Power Supply (CMPSU-750AXUK) £138.98
(£115.82) £138.98
(£115.82)
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) £129.98
(£108.32) £129.98
(£108.32)
Corsair Hydro H70 High-Performance CPU WaterCooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £79.99
(£66.66) £79.99
(£66.66)
LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive - Black (Retail) £57.98
(£48.32) £57.98
(£48.32)
Noctua NF-S12B FLX Ultra Quiet 120mm Flexible Cooling Fan £16.68
(£13.90) £33.36
(£27.80)
IC Diamond 24-Carat Thermal Compound (4.8g) £14.99
(£12.49) £14.99
(£12.49)
Your link shows the Coolermaster RC-1000 case :)
Copy-paste your shopping basket (or screencap it and host it on e.g. imgur.com) and show us that way, it's a lot easier.
Do you mind if I ask what you intend to use the system for? The monitor and graphics card you have chosen are pretty intense!
It may help those "in the know" suggest any changes or offer advice :)
For the price of the graphics card and SSD, you could buy a pre-built system from OCUK which would be perfect for some 'fairly' high-end gaming and general day to day use.
I'm really no expert, but atm you will be paying a lot of money for some fancy kit with a lot of potential which may not be used.
Hey, that setup looks sick! As a u2711 owner I can tell you games look so crisp and vibrant on that monitor. You might considder running 6950's in crossfire rather that having a single 6990 - better performance, quieter and 40% cheaper!
Is your plan to use the extra 120mm fan to replace the fan on the H70 Cooler? if so then no quarms here. otherwise if you don't mind waiting for OcUK to get stock in i'd go for the Antec Kúhler H2O 620 CPU Watercooler.
Performs just as well and is a lot quieter!
Only other question is do you need Windows 7 Ultimate? most people are fine with home premium. Do you need domain join, languages and bitlocker? If not the Win7 64 home is fine.
Small warning about the Cosmos case, you will be limited with the cable routing in it. the back panel has foam padding for noise reduction but it also stops you routing 90% of cables :(
couple of questions:
first off, do you already have a motherboard, because you havent shown one in your post.
also, will you be doing any major work in photoshop, video editing, animation, or CAD. if your not then i would suggest going down to 4GB of ram, because you simply wont use 8GB with gaming alone
*edit*
oh, and from what ive heard, if you get 2 6950's and 'flash' them to become 6970's and use them in 'crossfire' (both graphics cards working together on one screen) you will actually get better performance than your 6990 for about £150 less than the 6990
did a little hunting around, and this is the build ive come up with:
before you go ahead and order it, there are a few things i have literally no idea about, so i went for the same as you chose for:
- SSD
- CPU cooler
- case
- monitor
- thermal paste
- power supply (i know you will need 850W or above for what ive suggested, but i dont know if its a good one or not)
also, theres a comparison of the three versions of windows 7 here
my last question is, what are you planning on using your extra fan for, because the only fan that isnt included with the case is for the hard drives, and they really dont need fans
i am assuming the processor you have is the i5 2500k, or some other processor that will fit in the 1155 slot
Your basket
Product Name Qty Price Line Total
(£569.99) £683.99
(£569.99)
(£374.99) £449.99
(£374.99)
Asus ATI Radeon HD 6950 OC 2048MB GDDR5 PCI-Express Graphics Card £209.99
(£174.99) £419.98
(£349.98)
(£149.99) £179.99
(£149.99)
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £139.99
(£116.66) £139.99
(£116.66)
Zalman ZM850-HP Plus Heatpipe Cooled 850W Modular Power Supply £132.98
(£110.82) £132.98
(£110.82)
Pioneer BDR-205 12x BluRay RW / 16x DVD±RW Drive - Black (OEM) £99.98
(£83.32) £99.98
(£83.32)
(£66.66) £79.99
(£66.66)
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £79.99
(£66.66) £79.99
(£66.66)
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM 1yr Warranty (ST31000528AS) £37.99
(£31.66) £37.99
(£31.66)
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) £29.99
(£24.99) £29.99
(£24.99)
(£12.49) £14.99
(£12.49)
Sub Total : £1,958.21
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £22.20
VAT is being charged at 20.00% VAT : £396.08
Total : £2,376.49
(this comes out about £100 cheaper than your current rig, and includes a decent motherboard, which you didnt even out in your setup above)
£450 on a SS HDD are you kidding me? I suppose it is important for a game to load up quickly. NOT.
Personally, that's a waste of money, better invested elsewhere mate, in my humble opinion
That's a lot of money on a gaming rig... and most of it spent on the GPU, Monitor and a SSD...
Ouch.
enthusiastic about a hdd? hmmmph. The mind boggles!! :D
it wont make the game play any better from experience.. it'll just load quicker, pc boot up quicker. blah.
Well some people have different interests (certain GD topics) and having quicker HDDs just to shave a few seconds load-time off maps, Windows or whatever is always good.
An SSD is the best upgrade I could have made for WoW in experience, loading screens are so quick and it makes good use of SSDs. It's not really a new thing to be enthusiastic about HDD speeds, 10k RPM Raptors were the thing years ago.
Thank you for all your input, yes i do have the i5 2500k, does this look any better, please be gentle.
Your basket
(£569.99) £683.99
(£569.99)
(£374.99) £449.99
(£374.99)
Gigabyte P67A-UD5-B3 Intel P67 Chipset (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £249.98
(£208.32) £249.98
(£208.32)
Corsair Obsidian 800D Full Tower Case - Black £224.99
(£187.49) £224.99
(£187.49)
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card £214.99
(£179.16) £429.98
(£358.32)
Corsair HX 850W ATX Modular SLI Compliant Power Supply (CMPSU-850HXUK) £143.99
(£119.99) £143.99
(£119.99)
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) £139.99
(£116.66) £139.99
(£116.66)
(£66.66) £79.99
(£66.66)
(£66.66) £79.99
(£66.66)
(£48.32) £57.98
(£48.32)
(£13.90) £33.36
(£27.80)
(£12.49) £14.99
(£12.49)
