Why 1000mw and why 0.3%, decay heat is something close to 7% of total output of the plant, reactor 1 which was the first one in trouble is 460MW, the others are 784MW, as for water, you can't indefinately pump water in, because you can't just continually pump water into a limited space,
Drunkenmaster you educated in Nuclear physics, you seem to know a lot, just like you know how to manage Arsenal.
Why 1000mw and why 0.3%, decay heat is something close to 7% of total output of the plant, reactor 1 which was the first one in trouble is 460MW, the others are 784MW, as for water, you can't indefinately pump water in, because you can't just continually pump water into a limited space, theres no active cooling from the outside yet, which is something I assume that needs to be put in place to be able to comftably maintain the temperature inside the core.
Yes knowing that only the 6th and most recent of the reactors is 1100MW and the earliest reactor which had trouble is a 460MW reactor makes me an expert.
That depends if he's talking from the point of view that 'things continue as they are' or 'things get completely out of hand'. I agree that it would be foolish to completely rule out the possibility but as of now things should surely be coming under control or at least be stable. IF there is a second earthquake then the **** could quite easily hit the fan.
Are you sure they are not just discharging it back into the sea?
If you just continue pumping water in, and its turning into steam, and nothings escaping....... well, theres a point where you can't add anymore, or they have to be removing/exchanging the water/steam somehow.
I would be almost certain its not, it will be marginally radioactive at the least, by design the water in the core is partially radioactive. Meaning they couldn't just chuck it in the sea, I'm not sure theres an easy way for them to do it, plus, the water will be turning to steam so if they were chucking it out I'd think they'd be continuing the venting..
It's easier to see that helicopter hitting the cable in this video: http://www.youtube.com/watch?v=nbCcutzXzYg as you can actually see the cable unlike the other one, the rest of the video is interesting too.
Drunkenmaster certainly doesn't know any more about nuclear power than he does about managing Arsenal.
Decay heat is only 7% in the very instant (tiny fraction of a second) after a fission reaction. In the normal running of a reactor, it contributes around 7% of the total heat. The reactors haven't been running for days though, hence the decay by now to around 0.3%.
I said heat output of a bit over 1000MW. The numbers you are talking about (460, 784) are electrical output. Heat output is 2.5-3 times that.
1513: Water level in reactor 2 at Fukushima has fallen again, AFP now reporting citing Japanese media.
I know... Ive been saying about coolant activation in most of the thread. Did I need to add a big flashy signature for you to be able to remember the posts from users and their salient points?
The fact it terms into steam is how the steam raising plant works, particularly in a BWR where the reactor is the Steam generator... it doesnt necceisarily have to vent to atmosphere.
In terms of ALARP sea water discharge may well is better than popping the plant and melting the core....
I made the point about activation, and by design coolant activation is minimised.
They could have course have the condensing system fully running and hence need to pump the seat water through that such that the primary circuit doent have seawater in..... but no reports have said that, all are stating seawater into the reactor.
Tokyo Electric Power Co. said Monday fuel rods were fully exposed again in the No. 2 reactor of the Fukushima No. 1 nuclear power plant as of 11 p.m.
TEPCO said a steam vent of the pressure container of the reactor that houses the rods was closed for some reason, leading to a sudden drop in water levels inside the reactor.
snip
Secondly, hmm, why did reactor core 2 for instance only this morning manage to drop water levels so fast if the heat output should be circa 0.5-1% after a couple of days, doesn't that indicate something is heating the water up a lot more rapidly, they had been pumping in sea water until the pump ran out of fuel, then it apparently dropped quite quickly
I really don't know, supposedly the rods are damaged in the core meaning there could be much more than just minimally radioactive water in there, also with sea water theres a lot more things that can be made radioactive afaik, meaning it becomes less safe.
