Caporegime
- 18 Oct 2002
- block 16, cell 12
But how does the water look when it comes out? does it all get turned into steam? and if so, is the steam radioactive and where does it go?
I guess the problem with putting one 100m under the ground is, in the event of an earthquake, or tsunami, how do you get to it to fix it if the area becomes impassable to get down to it? And if it does leak out into the rock around it, how does this impact the local eco system? At least wit5h it being on the deck level you can get to it, as hazardous as that might sound to try to recover the situation.
