I don't suppose it's a publically available document, if so, e-mail in trust
Not good to hear.
... it would be nice to get a explanation of the health effects of dosages, rather than me trying to speculate by comparing numbers... heres a source i quoted y'day http://www.zerohedge.com/article/ga...nwind-ibaraki-disclosed-30-times-above-normal I think the document is part of the GE training package for future operators, so it's not publically available, so will stick some snipets up but won't send anyone the full thing![]()
I'm trying to understand the scale of it... How big is all the equipment inside the BWR? I.e. the reactors, fuel rods, pressure vessels etc? Is it all on quite a small scale, just contained within massive concrete walls inside the big buildings?
No worries, thought it was worth a punt anyway
Will search around the web to see what I can find anyway, I need my fill of engineering!
The following is the known status as of Tuesday evening for each of the six reactors at the Fukushima No. 1 nuclear power plant in Fukushima Prefecture, crippled by Friday's magnitude 9.0 earthquake and ensuing tsunami.
-- Reactor No. 1 - Cooling failure, partial melting of core, hydrogen explosion, seawater pumped in.
-- Reactor No. 2 - Cooling failure, seawater pumped in, fuel rods fully exposed temporarily, partial melting of core, damage to containment system.
-- Reactor No. 3 - Cooling failure, partial melting of core, seawater pumped in, hydrogen explosion.
-- Reactor No. 4 - Under maintenance when quake struck, fire caused by hydrogen explosion at pool holding spent fuel rods, pool water levels feared receding.
-- Reactor No. 5 - Under maintenance when quake struck.
-- Reactor No. 6 - Under maintenance when quake struck.
Anyone else have the urge to go and help?
Wouldn't know where to even start tbh
.Obviously it's not this simple, but...I'm surprised if there's no way to automatically withdraw the U-235 or whatever it is from the fuel rods / core, so that the U-236 is never created and the heat is not produced. Too much reliance seems to be placed on the cooling systems which are obviously fragile in cases like this.
My knowledge is next to nothing, which is why I'd be interested if anyone has any explanation of why nuclear reactors are apparently so fragile in their failsafes!? I suspect the answer will be something to do with cost / benefit at the design phase.
Fox news has now descended to telling jokes on the subject. Wow how low can you go?
The problem is they can't stop the reaction instantly..
Dont take this the wrong way...
but why have you even replied with a post like that? The first paragraph is a farce why not just start the post with the second one.
The fuel rod is the Uranium mix of 235 and 238 (enrichment takes the 238 value up) clad in a zircalloy material to contain the fuel. When you have had fission that uranium splits and the elements are still in the rod emitting a number of particles (radiation) and generating heay (decay heat).
U235 does not turn into a 236, this is fission, not fusion. The control rods have already stopped Uranium fission interaction.
If you take them out they melt, thats what the whole cooling thing is about. Plus you would need to take the lid off the RPV to take the rods out....
They are not fragile at all.
. Hence I'll have to disregard the rest of your post about the control rods and hope that someone that knows what they're talking about turns up.- I 'replied with a post like that' because I wanted to be enlightened, preferably not by some smug arse with mega-nerd-rage, especially one that obviously doesn't know what they're talking about. But hey, beggars can't be choosers.
not knowing EVERYTHING is apparently an offence on here.
