http://www.hse.gov.uk/radiation/ionising/doses/dose-pr.htm
Guidance
5. Notifications should recognise the need to apply ALARP to intervention, and not treat disapplication of the dose limits under regulation 15 as a general amnesty on the need to control doses up to the notified dose levels for emergencies.
6. The notified dose levels should be appropriate and justified in relation to the Operator's or Carrier's Hazard Identification and Risk Evaluation (regulations 4-6). The figures given below are intended as upper values, and lower values (above the dose limits) should be sought where reasonable. Emergency dose levels should not be seen by Operators or Carriers as a panacea to deal with accidents, and hence evidence should also be sought that further reductions in the proposed levels through planning and preparation are not reasonably practicable.
7. Subject to the above, emergency dose levels up to those listed below should normally be regarded as acceptable to HSE
8. Specific provision may be made explicitly for life saving. In this case it should be recognised that regulation 14(7) may disapply regulations 14(2), 14(3) and 14(4). However, it is desirable that for planning purposes the objective should normally be to apply the following levels:
Whole Body Dose:
500 mGy
Dose to Skin:
5000 mGy
These figures are expressed in milligray not millisievert as the appropriate dose quantity in relation to deterministic effects. Caution should be applied in conversion from one to the other.
Actions which carry a significant risk of the above benchmarks being substantially exceeded should only be taken when the likely benefits in terms of life saving clearly outweigh the risks to those carrying
