You don't need 1k+W on your power supply. Hope this helps![]()
Maybe YOU dont with your low end setup, but try running my rig with less than a 1kw PSU....
How do you know he isnt using it in a folding rig or a dual cpu/quad gpu setup etc?
just noticed your sig, what do you do to warrant like 20TB worth of space:O
I think he's probably glad that his laptop doesn't need a 1kw PSU!?![]()
yea, I know, didn't think about it being a laptop when I posted, and then cba to edit it after I re read his sig. But the point stands, just because he doesn't use 1kw doesn't mean others wont be. Along with the fact that most PSU's say that "normal" usage is around 50% load, and thats where they are the quietest as the fan ahsnt had to ramp up.
99% of people who post "spec me" threads on here don't need 1kW PSUs
