Hi guys,
Ok wedding season for 'me' starts on April 24th...for then I fancy some glass
For reference my current gear list is:
5D II
17-40L
24-70L
85mm 1.8
Potentials are with pros are...
35L
The lens is, in itself a simply awesome...the pictures it produces are incredible...whilst I wouldn't say this is a necessary lens as I already have that bit of focal length covered I would say that it's a VERY 'nice to have' and I would massively benefit from having one. I can get one brand new for £1035
135L
Another one from the holy trinity, except the obvious, currently I can't go higher than 85mm. So this would give me some extra reach, which would come in a lot of use during receptions and doing reportage work. The lens would get a lot of work I think. I can get this brand new for £715
70-200 2.8 IS
At my current budget limit of a grand getting one of these would mean a second hand MkI - which I don't have an issue with...having used one several several times now I'd say it's a pretty essential piece of kit (in the sense that a decent telephoto is essential not this lens specifically). Extending my reach to 200mm...one reason NOT to get this lens is that Mark has one, when assisting I use his...and when I do my own weddings I can incorporate hire of one into the quote. Second hand these are £900-£1000 last time I checked.
I also need to buy a grip with battery's, but I can order that this week if needed
hence not taking it into massive consideration, it's the above which is going to take the effort to save towards
Thoughts and opinions welcome!
Jake
5D II
17-40L
24-70L
85mm 1.8
35L
135L
70-200 2.8 IS
Jake
