also am i the only on thinking about the earthquake and tsunami not the nuclear power plant?
I'm thinking about the earthquake and tsunami as well, its the media that is scaremongering over the nuclear power plant.
I am the only one not worried about this turning into Chernobyl? I live near an AGR and I'm not worried in the slightest.
If you can keep your head when all about you are losing theirs.......you probably haven't grasped the seriousness of the situation![]()
Surely now is the time to look at just shutting them down as quickly as they can regardless of the damage it will cause to them.
BBC said:Radiation levels have fallen at Japan's earthquake-stricken Fukushima Daiichi nuclear plant, the government says.
Well thats part of the problem. Nobody has any clue what the situation is and the only updates we get are large explosions, which the media will blow completely out of proportion because they don't understand whats going on either. Surely now is the time to look at just shutting them down as quickly as they can regardless of the damage it will cause to them.
Yes it is created
Would you still say that if you lived close to one?
Status of quake-stricken reactors at Fukushima nuclear power plants
TOKYO, March 16, Kyodo
The following is the known status as of Tuesday evening of each of the six reactors at the Fukushima No. 1 nuclear power plant and the four reactors at the Fukushima No. 2 plant, both in Fukushima Prefecture, crippled by Friday's magnitude 9.0 earthquake and ensuing tsunami.
Fukushima No. 1
-- Reactor No. 1 - Cooling failure, partial melting of core, vapor vented, hydrogen explosion, seawater pumped in.
-- Reactor No. 2 - Cooling failure, seawater pumped in, fuel rods fully exposed temporarily, vapor vented, damage to containment system, potential meltdown feared.
-- Reactor No. 3 - Cooling failure, partial melting of core feared, vapor vented, seawater pumped in, hydrogen explosion, high-level radiation measured nearby.
-- Reactor No. 4 - Under maintenance when quake struck, fire caused possibly by hydrogen explosion at pool holding spent fuel rods, pool water level feared receding.
-- Reactor No. 5 - Under maintenance when quake struck, temperature slightly rising at spent fuel pool.
-- Reactor No. 6 - Under maintenance when quake struck, temperature slightly rising at spent fuel pool.
Fukushima No. 2
-- Reactor No. 1 - Cooling failure, then cold shutdown.
-- Reactor No. 2 - Cooling failure, then cold shutdown.
-- Reactor No. 3 - Cold shutdown.
-- Reactor No. 4 - Cooling failure, then cold shutdown.
==Kyodo
NEWS ADVISORY: Gov't orders injection of water into No. 4 reactor spent fuel pool at Fukushima plant 00:59 16 March
Ever heard the saying:
Live next to 2 of them at Heysham.
Doesnt bother me in the slightest & actually hoping Heysham gets the nod for building a 3rd power station as it'll do wonders for the local economy.
The heat in the reactors now is produced by residual isotopes decaying, not a full-blown fission chain reaction. It will by now be less than 1 per cent of the cores' normal output and chances remain good that the Fukushima crews will manage to keep the three hard-hit cores cooled such that they don't actually melt – though it is acknowledged that they are now probably damaged beyond economical repair, the more so as they were nearing the end of their lives anyway.
If they can't be kept cooled and the cores melt, this will drop the molten fuel into coolant remaining beneath, and it will solidify again in a less dangerous state. Cleanup will be more difficult if this happens, but provided the containment vessel remains unbreached there will be no massive release of radioactives. There is basically no chance of any Chernobyl-style incident*.
Has anyone read how they are getting water into the spent fuel pool in reactor 4? Theres a story on one of the main Japanese channels (a while before that announcement) that they were considering using choppers to dump water on top of the building but were weighing up the potential risk to the chopper and people in it?
For the people that know, just how radioactive is spent fuel vs the rods inside the core, what kinds of things will it be chucking out, and secondly, surely worried about the people in the chopper and being able to just dump water in there means the containment building is open at the top and the rods are essentially exposed to the outside now?
You guys should read this article, it is pretty much telling the truth with no scaremongering
http://www.theregister.co.uk/2011/03/15/fukushima_update_tuesday/
According to Flat Earth News, By Nick Davies there were only 56 deaths that are officially caused by Chernobyl and not the thousands that everyone thinks.
From the article it debunks another of the scaremongering
1701: Europe's Energy Commissioner Guenther Oettinger says Japan's nuclear disaster is an "apocalypse", adding that Tokyo had almost lost control of events at the Fukushima power plant, AFP report.
