Not sure I'd trust those Dyxum ratings if they rate the Tamron 10-24 so highly, by most regards it appears to be a dog...
They don't rate it highly. It comes out worst of the 4 I posted.
Except, landscape photography means tripod and any benefit of fast glass goes out the window. Although at the wide end even an aperture of 2.8 gives some DoF, you don't want to be shooting a landscape at 2.8 without a specific reason.
Maybe I shouldn't have said outdoors, but for most uses of an UWA a tripod is normally a requirement. The exception would be indoor group shots of people etc where you want a fast shutter speed.
I can shoot landscapes with my 24/1.4 on FX, with such wide angle lenses the DOF with the lens focused towards infinity quickly gets very deep. Of course anything nearby is out of focus, but at 11/2.8 on DX you'll struggle to get much out of focus, even on purpose.
The other advantages of fast glass are the brighter viewfinder and better autofocusing (more light on the AF sensor). You could argue that the better autofocusing is pointless if you're setting hyperfocal distances.
