Caporegime
- 18 Oct 2002
It seems to be a fruitless task to me, my understanding of the situation at the moment is it's not like the reactor has blown its top off and the rods are sat in the open with water being poured on them, everythings still largely contained.
Next to dumping enough water into the building to fill it to the level of the rupture (which would be 100& stupid) the heli trips will have little / no effect other than knock and dust layen particals back down to ground level?
Well, its the spent fuel pool which is right at the top so its not quite as silly, its not like they are filling it from the bottom up.
I just get the impression they'll need to essentially flood the floor and raise the water a little before it will tip over into the spent rod pool, how much higher I haven't got a clue, but it would seem from suggesting they have no way to monitor or it would seem, fill them up, which is most troubling.
SO it would seem they might be expecting reactor 5 and 6 spent fuel pool's to be heating up, just significantly slower than reactor 4.
Why they'd think radiation increasing exactly as smoke/steam starts pouring out of reactor 3 might be an increase from reactor 2 I don't know, it seems an over complicated take on what it might be, smoke pours out, radiation goes up...... chances of it being unrelated at least to me seem remote.
In terms of reactor 4, the fuel rods essentially are open to the air, and potentially not covered and continuing to heat up, and considering the 400millSv radiation levels were at the height of the fire coming from the area the spent fuel pond is in, again, I'd assume they were related.
THough the spent fuel rod pool being open doesn't mean anything inside the reactor can get out, the potential for one extra layer of contamination is just one extra thing that can go wrong at this point.
The big, according to many people unfalible containment building simply is broken on reactor 4. Worst place possible for reactor 4 as it has no fuel left in the reactor, though I don't know how full of left over radiation they are.
The problem I see is, reactor 3, basically if something leaked inside the containment building, so theres a leak from the reactor vessel into the containment building, that should not at all be able to get out. So the question is, where was the smoke/steam from, if its coming from inside the building through the containment building, well, the containment building again should not allow that.
Unless they left the vent open to prevent dangerous build up, basically IF the worst case scenario happens, you want to seal that containment building, the outter steal building, tight as hell so nothing can get out. To me it seems plant 4 is completely open to the spent fuel pool, and the reactor had been emptied completely into the pool, and reactor 3, has potential leak that let all that steam/smoke out of. So its rather looking like 2 of the 4 have a "way out" into the atmosphere.
