Upgrade itch - worth going from a Phenom X4 945 to a Phenom X6 1090T?
Depends what you use the machine for...
Also, if you wait until Bulldozer is released, the X6 Phenom IIs should drop in price a bit.
Absolutely zero benefit for gaming. Save your money till you can do a more worthwhile upgrade.
This.
I had a 965, bought a 1090T at launch, lovely chip, but zero benefit for anything gaming wise, hence I sold it and went back to a 965. :o
You wouldn't see a performance increase, although some games run a bit better if they're optimised to use more than 4 cores which isn't very many games.
I personally would wait until Bulldozer comes out, the prices of existing Phenom II CPU's would most likely drop and Bulldozer might be good value for money so you could get a 8 core CPU :)
guess it depends on how many have to shift :p
i think youll see a drop on 6 cores . unless bd isnt tht quick.
ill see how it fairs to whether i upgrade my p2 955 or not.
