Think I've Bricked my 5870
29 Sep 2004
Wilt of the Shire
I've had a bit of a mad day today flashing cards but I've hit a bit of a snag. I was trying to unlock my XFX 5870 so I could overclock it using afterburner. The card flashed ok but when I restarted there's no signal and it doesn't boot. I saved the original bios with GPU-Z so I stuck it on my usb drive and tried to flash it back. However, I can't even boot with the usb drive cos there's no signal (no beeps from card either).
I took my lowly 5450 out of my htpc and stuck the 5870 into the 2nd slot on my P6T board. I was able to boot with the usb drive but when I use atiflash it only shows the 5450 installed. It's the same with winflash. I know how to flash it back but just can't see the card to do it.
There's power going to the card and the fan spins but not sure what else I can do now. Anyone got any ideas?
Blind flash it.
Do you have a flash drive its a lot easier than a floppy?
Anyway extract the original bios of you haven't already, gpu-z works a treat.
On a boot disk flash/floppy, put the bios file e.g. master.rom and the program Atiflash.exe
In the Autoexec.bat use the command line.
atiflash -p -f 0 master.rom
or you can test it with the line
atiflash -i
which will just identify the card.
You don't know that as a single card it wouldn't be recognized. Blind flashing only uses the one card. You may need to use one of the other force switches as well.
-f Force flashing regardless of security checking BIOS file info check OR boot-up card
-fa Force flashing bypassing already-programmed check
-fm Forec flashing bypassing BIOS memory config check
-fs Force flashing bypassing BIOS SSID check
-fp Force flashing bypassing BIOS P/N check
Light switch has just come on and I know what you mean now! I'll try to blind flash it tomorrow, today has been a long day :)
There are services out there (if your efforts lead no where) that will be able to remove the bios chip and flash it in a special device (or even replace the chip itself).
If it's a non-reference design 5870 try using Sapphire Trixxx for overclocking it instead as it works with some non-reference designs, although not all unfortunately.
The v3.02 public beta can be found by googling it.
