Silverstone Temjin TJ11 in the post
Hi 84,
Thanks a million for your help.I watched the vid,thats the way i mounted
the rad so mine will be exhausting hot air.
Have i installed my ram sticks right?Have 2 of them installed with the stickers
facing towards the cpu in slot 1 and 2(nearest the cpu).
Any time.
I don’t know the lay out of the motherboard, however the RAM can only go in one way, so aslong as the side pins are clicked in place it should work.
I’ve just looked at a diagram of the board, not knowing exactly what the manual suggested but in my experience the RAM usually has gone in slots 1 and 3 then if you have more than 2 sticks in slots 2 and 4….. Just turn the PC on so long as it fires up the RAM is installed correctly. Go into BIOS and see how much memory its picking up.
Post a thread in the memory section asking, because as I said I don’t know that mobo.
windows 7 ultimate,waiting for it in the post probably wont arrive until
friday.
I have changed the ram sticks to slot 1 and 3.
just connected power cable to motherboard and to 6 pin connecters to
ati 4870 gpu.
i will post a pic in a few mins.
[/URL][/IMG]
going to install wd velocoraptor 300gb next.
i have 2 raptors for raid 0,should i just install 1 first?
By the way, most fans I've ever worked with are marked with an arrow on the side of the frame showing the direction of the airflow.
TheGoon84, did you powder coat your TJ07?
Yes mate, powder coated white on exterior and black internal:
friday.
ati 4870 gpu.
You’d have been better off just buying Home premium, Just make sure you install the 64bit version NOT the 32 bit otherwise the OS wont recognise the 8GB of RAM.
When you power it up if it doesn’t start make sure you change the RAM slots back to slots 1 and 2.
