Any C# Programmers out there?
Man of Honour
17 Feb 2003
Chelmsford
Hi, Pretty new to C# so bear with here.. I'm trying to create a form which shows a list of balances in a listbox.. but I can't find a way of aligning the currency fields in neat columns .. i.e. right justified but aligned with the previous entry.
Any ideas who I can do this or any other way of presenting the list?
18 Oct 2002
SW London
I'm assuming this is WinForms rather than WPF/ASP.NET/anything else?
It's been a while since I've used WinForms, but isn't there a TextAlign property or something on the control?
WPF makes this a whole lot easier if it's an option to use that (but you then have the WPF learning cliff to deal with!)
Man of Honour
OP
17 Feb 2003
Chelmsford
ah Apparently i can use listview:
Code:
 string[] row1 = { "s1", "s2", "s3" };
 listView1.Items.Add("Column1Text").SubItems.AddRange(row1);
However i only stiil getone column..
same here:
Code:
   ListViewItem item1 = new ListViewItem("Something");
            item1.SubItems.Add("SubItem1a");
            item1.SubItems.Add("SubItem1b");
            ListViewItem item2 = new ListViewItem("Something2");
            item2.SubItems.Add("SubItem2a");
            ListViewItem item3 = new ListViewItem("Somethin3");
            item3.SubItems.Add("SubItem3a");
            listView1.Items.AddRange(new ListViewItem[] { item1, item2, item3 });
30 May 2006
Have you created the columns?
Create the columns like this before adding the items.
Code:
listView1.Columns.Add("ColumnHeading1");
listView1.Columns.Add("ColumnHeading2");
listView1.Columns.Add("ColumnHeading3");
Man of Honour
OP
17 Feb 2003
Chelmsford
Hey Stelly,
Gotcha.. Many thanks I just may take you up on that. I attended a course a few weeks ago. The whole Object Orientation thing is a bit alien to me coming from a iSeries background so I'm just toying around at the moment. We are thinking of re-writing some of our systems to use C#/.NET in the near future.
Don
5 Oct 2005
Liverpool
Hey Stelly,
Ok dude... :)
Have been programming in C# since I was in uni, about 2001 so nothing new to me mate :D
Happy to help
Stelly
