- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Cubitek Mini-Tank Aluminium Cube Case - Black @ £114.98
The Tank Series is designed for high-end gaming PC users with space for large CPU coolers and long VGA cards, lots of storage space, superb cooling performance, inversion of the PSU, excellent heat distribution, and liquid cooling ready. Fits the Mini-ITX motherboard, 200mm long P/S2 PSU, 340mm long graphics cards, 2 x 5.25” ODD, 4 x 3.5” HDD and 2 x 2.5” HDD/SSD. A 5.25” to 3.5” converter is also included. Two full sized PCI slots, Dual PCI-E slots with 340mm of internal space for high end gaming cards.
- Model: CB-TKI-B210
- External Drive Bays: 2 x 5.25"
- Internal Drive Bays: 2 x 2.5" and 4 x 3.5"
- Size: 256 x 320 x 400m
- Anodized Aluminium
- Motherboard type: Mini-ITX
- Front I/O: 2 x USB3.0 / 1 x eSATA / HD-Audio
- Maximum Graphics Card length 340mm
- Maximum CPU Cooler Height: 200mm
- Front Cooling: 140mm Fan x 1
- Rear Cooling: 120mm Fan x 1
- Top Cooling: 140mm Fan x 1
ONLY £114.98 inc VAT.
BUY NOW
Cubitek HPTX-Tank Aluminium Big-Tower Case - Black @ £189.98
The Tank Series is designed for high-end gaming PC users with space for large CPU coolers and long VGA cards, lots of storage space, superb cooling performance, inversion of the PSU, excellent heat distribution, and liquid cooling ready. Aluminum full tower case designed for the EVGA SR-2 motherboard, the Full Tower HPTX Tank case fits 2 x PS/2 PSU, 9 x 3.5” HDD, 2 x 2.5” HDD, and 5 x 5.25” ODD. One 5.25” to 3.5” converter is included. Fits E-ATX and EVGA SR-2 motherboards, 220mm+ long P/S2 PSUs, and 340mm long graphics cards.
- Model Number: CB-TKE-B510
- External Drive Bays: 5.25” x 5 ( one 5.25” to 3.5” converter included )
- Internal Drive Bays: 3.5” x 9 + 2.5” x 2
- Size: 230 x 600 x 610mm ( W, H, D)
- M/B Type: EVGA SR-2, EATX, CEB, ATX, Micro-ATX, Mini-ITX
- PCI slots: 10
- Front I/O: USB 3.0 x 2 / E-SATA / HD+AC-97 audio
- PCI Space: Maximum Graphics Card length: 340mm
- CPU Cooler Height: Maximum CPU Cooler height: 190mm
- PSU Space: Maximum PSU length: 220mm
- Front Cooling: 230mm fan x 1
- Rear Cooling: 140mm fan x 1
- Top Cooling: 140mm fan x 1
BUY NOW £189.98
BUY NOW
Cubitek Magic-Cube B210 Aluminium Modular Tower Case - Black @ £172.99
The Magic Cube series are personalized PC chassis, each cube holds different components. One M/B cube, one storage cube, and one optical cube. All three cubes can be joined together or kept separate, according to personal preferences. All panels can be removed, allowing cubes to be used as “workbenches” to test equipment. The cubes separate PC components into different heat zones, allowing for cooler, quieter computing.
- Model Number: CB-MA-B211
- External Drive Bay: 5.25” x 4 ( including a 5.25” to 3.5” converter)
- Internal Drive Bays: 3.5” x 8 + 2.5” x 2
- HDD Cube (fits 3 HDDs)
- Material: Anodized 5052 aluminum
- M/B Type: ATX / E-ATX
- PCI slots: 8
- Front I/O: USB 3.0 x 2 / HD+AC-97 audio / Mini USB Type B (Mini to Micro USB adapter included)
- CPU Cooler Height: Maximum CPU Cooler height: 180mm
- Fan: M/B Cube / Front: 140mm fan x 1; Rear: 120mm fan x 1; Top: 140mm fan x 1
- HDD Cubes: 140mm fan
BUY NOW @ £172.99
BUY NOW
BUY NOW
- PCI slots: 10
BUY NOW £189.98
BUY NOW
- PCI slots: 8
BUY NOW @ £172.99
BUY NOW
