Think he is making the point that if in theory the reactors stayed on they would have carried on powering the normal cooling systems.
No idea whether that would have really worked though![]()
?? Elaborate please.
Edit: Surely you dont think the power plant powers its self?
Well obviously but once it's built power is power.
Oh yeah don't get me wrong I definitely think turning them off was the right call. Just agreeing norm's point of it being sadly ironic.
MeEsH - They'll be on the grid with other stations to take power, but a fully operating power station isn't going to need power coming in to it under normal use. It's a moot point anyway.
Not realy, what would happen say to a plant with only one reactor if it needed to shut down?
Where did the supply to all the seriously demanding equipment come from before the reactors were brought online?
What would happed if the reactors needed shutting down, like in this case minus the tsunami?
All stations are fed from an external source.
That ignores the cost of discovering how to make them in the first place. Same applies to intel, making cpu out of sand and plastic and charging 20x what it costs them to make
Isn't it ironic that the disaster at Fukushima was a result of the reactors automatically shutting down?
It amazes me they didn't consider this eventuality.
They have (had) an 8 hour battery supply, in the case of power outages, or supply issues, or the diesel gennies kicking in.
In this case, the batteries worked perfectly, but the diesel gennies did not kick in, and when the batteries ran out, this was the outcome.
The problem is with the cooling system not working, not the actual reactor(s). Imagine someone draining the cooling system on your car and then disconnecting the fan on a hot summers day....... stand back !
Yeah the cooling system failed because when the reactors shutdown there was no eletricity supply, so they had to revert to the diesel generators.
If they hadn't shutdown, or at the very least kept one reactor running, the cooling pumps would have had ample power.
Yeah the cooling system failed because when the reactors shutdown there was no electricity supply, so they had to revert to the diesel generators.
UNfortunately they are seemingly quite a bit beyond just getting the cooling back on, they should be able to re-establish core cooling, but the open pools are the bigger danger now.
If the system failed, the pool could boil, turning the plant into a lethal sauna filled with clouds of radioactive steam. And if earthquake, human error or mechanical failure drained the pool, the result could be catastrophic: a meltdown of multiple cores taking place outside the reactor containment, releasing massive amounts of radiation and rendering hundreds of square miles uninhabitable.
See this is what I was on about. Why the hell can they not put the cooling system deep underground in a sort of bunker (since it's so important) and power it from the main reactor?
These things need to be kept cold and it was the absence of cooling that caused a partial meltdown and the problem we have now. Apologies if Im talking sh** here but is this not the problem??? Surely they should have made sure the cooling system would work no matter what??
