Hi folks,
Just putting together my new system, got everything sorted and stress tested etc, but the H70 pump makes a recurring rattling noise - sounding much like a cable vibrating on a case fan. That is basically the only noise from my system. It isn't loud at all, but it can be heard with the case fully sealed in idle. In full load the GFX obviously start to make noise so it drowns out the pump rattle.
It's a brand new build, so might this be a teething issue or one that will recur be prelude to device failure?
The device is reporting around 1400RPM in BIOS, so I believe that is OK. But as for the noise... ?
Specs:
i7 2600K (no OC yet)
8GB Corsair RAM
Corsair 700D Case
3 x 120GB SSD
3 x Viper fans
1000W Corsair PSU
2 x 6970 GFX
Corsair H70 Cooler
I've made a short vid with my iPhone of the noise - http://img37.imageshack.us/i/9pco.mp4/
The iPhone picked it up very easily, but PC volume might need to up loud as the *.mov is quite quiet.
Specs:
8GB Corsair RAM
Corsair 700D Case
3 x 120GB SSD
3 x Viper fans
1000W Corsair PSU
2 x 6970 GFX
Corsair H70 Cooler
