Caporegime
- 13 May 2003
- Warwickshire
How do you work that one out? The SG07 is much more expensive on account of coming with a 600W PSU. Which is unnecessary in this instance.![]()
My mistake, I was comparing the SG06 to the SG05, but I notice now that you were referring to the SG07 in the spec list above
.Regarding the HD6870, that's awesome
.Why do you need to go SandyBridge if you are planning on putting a GTX460 in there and only an i3?
In terms of performance/cost you'd probably do better with the H55 chipset and you can OC that as well and not have to wait and pay for the Gigabyte P67 board.
The only thing that would concern me about taking that option is the fact that H55 doesn't seem to support SATA-III (6 GB/s) and with very fast SSDs likely to be at the front of the storage game for a long time to come, you're kind of limiting yourself especially without the ability to use a controller card.
