- 14 Jan 2011
My system:
Intel i5-2500 @ 3.30Ghz (not interesting in overclocking, sorry!
Asus H57 Evo motherboard
4GB Corsair Ram
1GB ATI HD5770
1x SSD
2x HDD
Antec True Power 650W
SG-04 SFF Case
The problem:
Basically I built this computer myself about 2 weeks ago, and the Antec Power Supply has started to make this REALLY ANNOYING hi-pitched buzzing noise. It either happens as soon as I turn the computer on, or it will happen after the computer has been on for a while. It lasts for several minutes and it's so loud you can't really use the computer while it lasts.
Also, even when the power is connected, but the computer turned off, the Power Supply still makes a slight buzz, more than I would expect.
So I think I am going to return the Power Supply.
Replacement:
I am considering exchanging it for this PSU:
http://www.silverstonetek.com/products/p_spec.php?pno=ST50F-P&area=usa
Would this still power the above system ok, even though it is 150W less than the Antec?
Is this a good PSU or should I stop trying to save money and go with something more expensive, like Corsair or Seasonic? I need something fairly small and modular, because my case is so small!!!
Should I just swap it for another Antec, and hope it works better than the last one? I have read some bad stories about Antec products.
Thanks in advance for any suggestions!
*Jen
4GB Corsair Ram
1GB ATI HD5770
1x SSD
2x HDD
SG-04 SFF Case
The problem:
Replacement:
*Jen
