Is this the point where I tell you my insurance on the Cayman S is £450![]()
£900 for my Corsa..... Yes Vauxhall Corsa......
What is the world coming to!
Gibbo. Mrs Spie likes it, so you may proceed![]()
Woot Woot
so you can have a bit of extra noise and keep the warranty. You paying or is he for the mix up over advertised spec ?
Am just gonna do as Housey/DiamondMark suggest and get it pre-inspected by a specialist or request they themselves take it to Porsche for the 111 point check so I have no issues getting warranty. Can't see an issue as so far all my phone calls and emails have been replied to timely and professionally, seems like a decent honest dealer, but not come across anyone who has said a bad word about them which is a good thing.![]()
Good stuff, it makes sense with any 911 to get it checked out for peace of mind. It's the less obvious things that can be expensive. I'm sure the car is straight as the dealer seems to have a good reputation, but it's things like Rev range 2's I'd like to know about and any leaks. I seem to recall Andy Fearns spent hours going over my GT3 for the buyer, who paid for the inspection himself. Went down the panels with lights checking paint, picked up the door paint which he said was obviously done to a very high standard and also plugged in the Porsche computer and checked Rev ranges, running cycles and all sorts of other stuff. Then onto the ramp and full underbody check, engine check and suspension check. Sadly is was perfect so the sale went through![]()
I envy you no end!
Nice whip! Why can't I get a job that allows me to own an EVO and a Porsche??![]()
Dealer has booked it in with Porsche, goes in tomorrow at 10am for a 111-point check along with a print out of the DME Scan. So as long as there is nothing in range 4 or above and the 111-point check does not come up with thousands of pounds of work required I should be taking delivery Wednesday/Thursday.
The dealer has also sourced me a PSE system for £950 fitted which they shall do next month.
Fingers crossed Porsche don't say its a lemon, but the dealer is confident its an immaculate car, lets hope so.
Thats the best 200 quid odd you are going to spend![]()
£216 in total, but yes worth every penny, now lets just hope its not a lemon.![]()
Flash, just flash
So all you need to do after you pick it up, is to get it Zymol'd![]()
I bet its not, but how much would you kick yourself if it turned out to be for the sake of a days delay and a couple quid![]()
