OcUK Value 7/16" Tubing Green - 1m
Most 7/16th inner diameter tubing has a 5/8th outer diameter, but I am not 100% sure it will apply to this stuff too. I would guess though that it is.
This is what I'd hoped, which would give it a nice 3/16th's wall thickness like the decent stuff.
Thing is I've bought cheapo tube before (not from OCUK) and it only had 1/16th wall thickness.
This is why I ask :) Just wondered if any of you had bought some.
LOL
I sent a web note and ask,
OcUK Value 7/16" Tubing Orange - 1m
Could you please tell me the outside diameter size for this tubing, or the wall thickness.
regards
The reply came
Thank you for your web note. The thickness of the wall is 3mm and the diameter of the tubing is 1cm.
Regards,
Me like a fool assumed he was referring the diameter to the inside even though I ask for outside diameter measurements, but 3mm wall thickness must be inside eh, especially as its advertised as
This tubing is ideal for use with 1/2" watercooling systems and blocks
How wrong I was, see below
For those that want to know
The specs for this tubing are.....
Outside Diameter : 11mm ( 7/16 *)
Inside Diameter : 8mm ( 5/16 * )
Wall Thickness : 1.5mm ( 1/16 *)
Not suitable for use with 1/2" watercooling systems and blocks
*approximately
Suitable for 11/8mm compression fittings only then. Slight difference between them and say 1/2" barbs. RMA time I guess.
RMA is hardly worth it though, probably cost me more in postage than what the tube cost.
This product has been on the website for a while, I cant be the only one
I just don't understand how a company who deals/specialises with these type of products can make a silly mistake like that.
I ordered some orange thinking it will be ok to use to flush my rads and such stuff, does not fit 1/2 inch barbs, it's just come and its not suitable for anything lol, time for the bin as it's not worth rma
This is the problem if you ask me, I don't think you could say OCUK specialise in water cooling products to any great extent.
Yes I now agree whole heartedly, especially those who cannot visually see the difference between 7/16 inside diameter and 7/16 outside diameter, certainly do not know their onions.
To be fair I have received an apology and an offer of refund inc postage. Also told the site pages will be amended
