Stop recommending this game!
I really cant justify the £250+ its gonna cost
ps3ud0![]()
Cheers for that - I know I need to change my GFX card for sure so just umming and ahhing - have to admit pretty much all my gaming has moved over to the consoles but it games like Total War that keep my PC in use - that and my stupidly large Steam library, I get owned by sales...
Just keeping an eye on nVidia performance as I was gonna get that Gigabyte 480GTX with the better cooler while its on offer but it seems some are having so right proper issues with it and Total War - I assume nVidia will be updating drivers to combat it sooner rather than later...
ps3ud0![]()
An underused 280GTX with a Q9450 - all stock Im afraid too...
ps3ud0![]()
It should work just fine if you overclock them decently.
Yeah I was following Jono8s experiences earlier in the week so that was stalling my 480GTX purchases - I know its just drivers (hopefully a safe assumption), but I dont want to shell out for a new card when Im not sure when those might appearAvoid Nvidia with this game for now - hopefully for Nvidia users drivers will fix the stutter/framerate problems. It would be a waste of money if they don't though. At least the Q9450 in your system will be up for the job.
Get the game, see how it runs, and then upgrade if you need to.
It might surprise you, the recommended specs are well over the top.
Excellent, thats good to hear - to be honest coming from a PS3 Im sure I wont be as critical as some (so used to jaggies!!!).It should work just fine if you overclock them decently.
I have to be honest Im not really clued up on the whole overclocking thing, though my system is pretty much primed for it (have a MO VFD to control fans for temps; spot fan for the RAM; a TRUE with 2 fans and a old school Stacker case with the side case fan blowing over the mobo).
Sounds like theres a good chance my system isnt that old hat (loathed to upgrade it do to the reduced usage it gets nowadays) - will pick up the game this week then
ps3ud0![]()
What settings are you using? My framerate stays pretty smooth even with most things on Ultra (but with only HDR and Vignette checked). I have a Q6600 @ 3.2 and a 460 GTX. Dropping down from Ultra to High on unit detail and shadows helps quite a bit.Units make my cpu cryCheck out the bottleneck!
Scene without units - 99% GPU usage
[pic]
Some units - GPU usage plummets to 45%
[pic]
When units are moving and colliding with each other it again plummets to 36% ( and i have seen lower!)
[pic]
I'm really sorry to ask this guys, as it smacks of laziness on my part... but now that people have been able to check the game out, I'd like to ask TW veterans if it's a worthwhile purchase? If you've played any of the previous TW games before, where does Shogun 2 rank, or how does it compare?
Basically, I trust the opinions of you fellas far more than the majority of review sites out there! I'm itching for some Total Warring, and would love to buy this, but am a little hesitant after not liking ETW out of the box.
I've been playing since RTW. Medieval 2 was the best up until Shogun. The only downer about Shogun is that it's only based in JapanI love TW games for the mere fact that I can conquer the world (or at least a good portion of it)!
