Yeah I am serious, it would seriously bug me, I don't have the card yet, I got about another week or so before ordering, but yeah I would want the block to say 6950, not 6970 which the card will never be if I buy a 6950, I would kinda feel stupid parading it with a 6970 block and underneath is a 6950, god damn this is difficult
Why not just flash it to a 6970... then the label would be right![]()
No, not yet thats why I am here discussing itsounds like you have already made your mind up as you were writing the original post....if it bugs you get the 480gtx its a cracking card at a cracking price just now so what you waiting for?
never, I just had the xr2 that had them as standardyou definatley never had go faster stripes on your ford fiesta when you were 17![]()
Just think though, the difference between a 6950 and 6970 is basically what BIOS they have on them. If you flash the 6950, it'll be a 6970.
never, I just had the xr2 that had them as standardthat thing was on rails.
Now that ^^^ is why I am here discussing it, I need a little persuasion
But I still got my fingers crossed EK have heard me and will release a block labeled for the 6950, within the next week or so.
This has to be the worst situation, for one the block ain't right on a good card with good potential to unlock to a much better card
whats not right about the dangerden block above? doesnt say 6970 on it but is specially made for 6950/6970 because as someone said above they are the same card with different bios settings....
problem solved surely?
Originally Posted by jigger View Post
Get the new Swiftech block. IIRC that just says ATI HD6900
well i got rads that are EK and cpu block that is EK, res as well and wanted to make a bit of a theme of EK stuff
There's your answer.
I still hold my original suggestion to flash the 6950 to 6970... I'm not the only person to suggest it and it solves your problem and gives you a better card for you money.... it just makes sense.
There not really the same card though are they, it will allways be a 6950 running a different BIOS and have read a few horror stories of bad flash's and such obviously there is no guarantee it will unlock to the same performance of a 6970
I am usually the unlucky one when it comes to buying hardware that is supposedly best value because it does this and that and then when I try to do it myself there is usually some problem that makes me revert the change anyway, I am just unlucky like that.
Techpowerups Test Results updated until Feb 1
Link
Full 6970 flash(not unlocked shader flash!)
471 Cards tested.
456 unlock fully to 6970.
14 unlock to 6970 but rendering errors.
1 did not unlock.
You can add my 2 6950's to the success rate too.
Are you ******* kidding me? The reason a reference design can be flashed to a 6970 is because it is a 6970!
This thread is seriously making me laugh. I sure hope to god we're not all getting trolled because I would feel bad for ages if we were.
Get the 480 it will clock up to 900 core under water, nothing AMD have can compete with that, dual GPU crossfire card not included.
