So ladies and gents, was fermi a fail after all?
Fermi is a compromise between GPGPU and gaming. Not ideal for gamers because of the extra power consumption.
If nVidia could splitstream the architecture in Kepler that would be much better.
Add up everything in your system that's pulling 12v and subtract from the PSU 12v rail. If your have 5-10% in reserve you should be fine.
Or look at Nvidas website who say to use a 600w PSU for the 480.
No need for smart ass mathematics is there really:)
http://www.nvidia.com/object/product_geforce_gtx_480_us.html
Thermal and Power Specs:
Maximum GPU Temperature (in C) 105 C
Maximum Graphics Card Power (W) 250 W
Minimum Recommended System Power (W) 600 W
Supplementary Power Connectors 6-pin & 8-pin
High Dynamic-Range Lighting 128bit
Unified Architecture
Well thats well beyond what I am capable of lol:)
but not a massive system, i5 750 oc to 3.7MHz, 4GB ram, 1 ssd, 1 500gb hdd, Asus d1, 1 dvdrw, and 1 10w pump, and 6 120mm fans and 2 140mm fans, you think I will be ok, seems from others I should be
Over all it was a good card, People whining about the temps... cmon srsly... who is going to leave a stock cooler on it anyways, So called enthusiasts thease days!.
