Hey guys, have recently got a Phenom II 965 and thought I would give overclocking a try as I have seen it is a very viable overclocking CPU.
At first I didn't use the BIOs to overclock, instead I used the AMD overdrive. Did not like it. So I started to use the BIOs instead.
Firstly I changed the multiplier to x18 and left the rest at default, it ran very stable (3.6GHz clock). Then I decided if I could push it that little bit further with x19 (3.8Ghz). I didn't really notice an problems but the clocks would randomly reset to stocks, I heard this was a safety feature. So instead I decided to alter the Bus speed and had the same results when getting close to 3.8GHz even when changing the voltages slightly.
This is as close as I could get to 3.8GHz without having issues, it seems fairly stable when using IntelBurnTest and Prime95 to stress test.
My Specs:
Asus M4A785TD-V EVO mobo
AMD Phenom II x4 965 BE
Artic Cooling Freezer 7 Pro rev.2
OCZ gold low-voltage 1333Mhz ram
Corsair tx650w PSU
My question is, could this be a hardware related problem or am I doing something wrong? I used to have a Q6600 OC'd without any problems so I do have some experience with overclocking
Any help would be appreciated, thank you!
My Specs:
Corsair tx650w PSU
just my background.
