High Performance CPU cooling.
If you are looking for effective cooling at a great price, then you should take a look at the Corsair A50 High-Performance CPU Cooler the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.
Today Only at the reduced price of £29.99 inc VAT
The ultimate in immersive HD gaming.
Consider yourself a power gamer? This is the graphics card for you. AMD Radeon HD 6990 Graphics Cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. Now available,
Today Only at the reduced price of £515.99 inc VAT
HIS ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card @ £515.99 inc VAT
Designed for the power gamer, AMD Radeon HD 6990 graphics cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. The AMD Radeon HD 6990 offers the ultimate in immersive HD gaming and computing with native support for up to five displays using AMD Eyefinity multi-display technology, with six display support possible via DisplayPort 1.2 components available for purchase later this year. The AMD Radeon HD 6990 graphics cards also feature a dual-BIOS toggle switch, allowing enthusiast gamers to unlock the card and rev up the clocks and voltages for even more performance. Finally, AMD HD3D technology provides a cutting-edge stereoscopic 3D gaming and movie experience, thanks to HDMI 1.4a support.
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
Only £515.99 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £29.99 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.
- Compatible with Intel and AMD systems
- Three 8mm copper direct-contact heatpipes
- Aluminum fins
- Low-noise, low-vibration 120mm fan mounted on rubber studs
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want
- Air flow: 50 - 61 CFM
- Noise level: 26 - 31.5 dBA
- Two-year warranty
Only £29.99 inc VAT.
ORDER NOW
Features:-
- ROPS: 64
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- Aluminum fins
- Two-year warranty
ORDER NOW
*HINT HINT*
