Live box Ethernet cable cat number?
4 Feb 2011
What CAT is the ethernet cable which comes with the orange livebox?
because my mum said that I will get that put in my room and I'm wanting to run my PC on a 5 cat cable. just want to know because if it's not 5 i'll go buy one :)
Thanks '-'
Why do you want cat 5? why not Cat 5e or cat 6 to allow for gigabit in the future? I am assuming that it is going through a wall or something so you may as well allow for upgrades in the future?
well those speeds wont be happening any time soon and the 360 will be a fond memory by then
yea but you said for pc as well, and GB routers are common place now (if buying new) and almost all pc's have gb now, just pointing it out as for the cost of a couple of quid it saves re doing it at some later date.
