NZXT Hush 2 Silent Gaming Cases - Pre order now.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
We have the NZXT H2 "Hush" Silent Gaming Cases available to pre-order now. With the black edition landin in about 12-14 days time and the white around 2 week after that.
NZXT Hush 2 Silent Midi Gaming Case with Fan Controller - Black @ £89.99 inc VAT
Noise – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. If you are a professional gamer, avoid it at all cost. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
- Dimensions: 215 x 466 x 520mm
- Steel Chassis with Aluminium finished front
- Motherboard Support: E-ATX, ATX, mATX and ITX
- Front I/O Ports: 1 x USB3.0, 3 x USB2.0 1 x eSATA
- Support for GFX up to 315mm long
- Drive Bays: 3 x 5.25" & 8 x 3.5"
- Expansion Slots: 7
- Front Cooling: 2 x 120mm Fans @ 1200 RPM (included)
- Top Cooling: 1 x 140mm Fan (optional)
- Rear Cooling: 1 x 120mm Fan @ 1200 RPM (included)
- Bottom Cooling: 1 x 120mm Fan (optional)
Only £89.99 inc VAT.
ORDER NOW
NZXT Hush 2 Silent Midi Gaming Case with Fan Controller - White @ £89.99 inc VAT
NNoise – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. If you are a professional gamer, avoid it at all cost. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
ORDER NOW
Wow, really nice looking. Loving the drop in hard drive cage on the top and a great price. With this and the phantom NZXT's line up is looking really good.
It is pretty cool looking buit I still prefer the Thermaltake Element S for a nice clean case and if its built like the Element G its fantastic build quality! :)
full review?
The full review for that vid is here and there's quite a bit more detail. About 2cm to 1" behind the mobo tray - pretty good going! You could just stuff all your cables behind it and forget about using a million cable ties and electrical tape like I had to with my P182. His NH-U12P only just fits though, but should accommodate pretty much everything tbh.
I think this isn't a bad case, but it isn't a great one either, not quite sure where to place it.
