Hello, we have some fantastic pricing on some great lines. Do not miss out as the pricing will be going up on Monday.
TT Esports Gamers Headset Shock - White @ £36.98 inc VAT
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound
- Quality 40mm speaker driver with enhanced bass performance
- Noise cancelling microphone for communciation in gaming activities
- Control Box with In-line control box for instant gaming sound control
- 10 Levels adjustment for a perfect fit
- Foldable design
- Gold plated 3.5mm connctor
Only £36.98 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £36.98 inc VAT
nonl2br
- Foldable design
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Gaming Headset @ £46.98 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Only £46.98 inc VAT.
ORDER NOW
Creative Draco HS-850 Gaming Headset @ £31.98 inc VAT
The Creative Draco HS-850 gaming headset delivers sounds so real you'll get absorbed into another reality in no time. Designed and tuned by top acoustic and gaming designers, large Neodymium drivers produce explosive bass that will blow you away while full-size circumaural earcups in soft leatherette provide comfortable usage. For travel convenience, swivel earcups fold neatly for easy storage and to switch to music listening, simply detach the noise-canceling microphone and use it as a pair of headphones. Feel the game expand all around you with the Draco HS-850. Let the battle begin!
- Realistic sound, explosive bass
- Comfortable full-size earcups isolate noise
- Travel-friendly and easy to store
- Headset or headphones - it's your call
- Flexible noise-canceling microphone
- Convenient in-line volume controls
- 1 Year limited warranty
Only £31.98 inc VAT.
ORDER NOW
Arctic Sound P281 Professional headphones @ £18.60 inc VAT
The ARCTIC SOUND P281 is a pair of DJ headset that combines stylish appearance, durability and practicability in an affordable package, made to meet the specific requirements of professional DJs. The ARCTIC SOUND P281 contains a 50mm drive to ensure high-fidelity sound and is constructed with ergonomic features for long hours of usage.
The ARCTIC SOUND P281 has an adjustable and padded headband to provide excellent listening comfort. Leather lining and soft cushion on the earcups provide secure fit and allow the headset to rest comfortably over the ears. Upper headband is made of artificial leather lining to emphasize its stylish appearance, while the underside headband contains netted nylon for sweat absorbing. Its circumaural design wraps firmly over the ears and provides a high level of noise isolation. Hence, this tightly closed and highly insulated structure captures delicate sounds for DJ in noisy ambient settings.
As a DJ headset, the ARCTIC SOUND P281 is designed for music and sound monitoring. The headset can be bent and flexed in many ways. Its 90-degree swivel mechanism on both earcups allows DJs to have the flexibility for single-sided monitoring. The folding design in the ARCTIC SOUND P281 has flexible joints, allowing DJs to fold the headset to half its size for space-saving, travel, and protection. Coiled cable on the headset is heavy and sturdy to prevent excess cable from sitting on the floor or DJ table.
- Superior output power
- Extra-wide frequency response
- Lightweight and comfortable
- Designed for DJs
- Adjustable headband with 90-degree swivel earcups
- Gold-plated standard 3.5mm plug with 6.3mm adapter for wide compatibility
- 2 Years warranty
Only £18.60 inc VAT.
ORDER NOW
Roccat Alumic Gaming Pad @ £35.98 inc VAT
With two very different surface structures, the ROCCAT™ Alumic meets the highest demands of both low and high-sense gamers. Each side also features a different design. Made from high-quality aluminum, the ROCCAT™ Alumic offers maximum stability and durability. Extra-large mousepad feet ensure the mousepad stays rooted to the spot while offering the ultimate in mouse control when gaming. It also includes a gel-filled wrist rest for maximum comfort.
- Double sided mousepad
- Anodized aluminium core
- Including gel wrist rest
- Non-slip rubber feet
- High quality materials
- Easy-to-clean surface
- Optimised for speed & control
Only £35.98 inc VAT.
ORDER NOW
- Foldable design
ORDER NOW
nonl2br
- Foldable design
ORDER NOW
- 2 Years Warranty
ORDER NOW
ORDER NOW
- Designed for DJs
- 2 Years warranty
ORDER NOW
ORDER NOW
