Look what just showed up :D
18 Oct 2002
Florida/UK
Will have it fitted tomorrow. By far the most expensive exhaust I've ever bought and that's including some pretty stiff competition.
I can't get over how light the whole thing is but here's a sneak peak :D
Look forward to hearing it.
I have a custom made titanium 4" pipe on my GTR. Can pick it up with two fingers probably weighs less than a 1KG and sounds insane.
Can't wait to hear the sound clips when you have it installed.
err .. like this ? :p
Does this kind of thing void your warranty in the States?
exhaust you can usually get away with providing your dealer knows and understands you. There is grounds for both rejecting and accepting a warranty claim in the small print. Which they do is up to the dealer.
Nice is it titanium? What it going on?
Whole system is Ti yes :), going on a new M3.
Big box for a stick on exhaust tip!
I know right? Thank god while looking through the packing material I found that they'd used these parts to pad out the exhaust tips.
There are of course 2 of these!
The general understanding here is that if they can attribute the part to causing the failure of whatever died then yes, warranty void. I'm sticking to very conserative mods with this one because I want to protect myself from that. About the worst thing they can void my warranty on in this instance is an O2 sensor or an exhaust hanger, I'm in no danger of losing any warranty on the engine or any other part of the car at all.
The outer tip, not so much, but inside it will.
If you want that look just apply a bit of gentle heat using a bluetorch :D
If you want to take a blowtorch to a $5500 exhaust be my guest. The tips alone are almost a grand :/
I'll let nature run its course hehe
