**Lightning Strikes Twice - OcUK Exclusive on first UK delivery!**
OcUK Staff
17 Oct 2002
OcUK HQ
Lightning Strikes Twice!! MSI Launches N580GTX Lightning and R6970 Lightning
Up to 1GHz Core Clock Overclocking Potential on GTX580 with Power4 Architecture and Twin Frozr III !
MSI, the leading global graphic card and motherboard manufacturer, today unveiled its two flagship cards: the N580GTX Lightning and the R6970 Lightning. These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled N580GTX Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Industry-leading Power4 Architecture for Overclocking Reliability
The MSI N580GTX/R6970 Lightning graphic cards inherit the impressive Power architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next LevelThe all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 21°C /26°C lower than the reference board when the N580GTX/R6970 Lightning are operating under full loads. Fan noise is also 5dB/11dB lower in addition to having much higher overclocking potential.
Overclocking Potential Unleashed with GPU/Memory/PLL(VDDCI) Triple Overvoltage
The MSI N580GTX/R6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of N580GTX Lightning is 30%2 higher than the reference board and offers enthusiasts ultimate performance.
King of Extreme Overclocking
For hardware enthusiasts, the MSI N580GTX/R6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios and XtremeCool3 switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the N580GTX/R6950 Lightning the ultimate graphic cards for extreme overclocking.
Carefully Selected Materials
The MSI N580GTX/R6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
MSI N580GTX Lightning 1536MB GDDR5 PCI-Express Graphics Card
CUDA Cores - 512 Units
Core Clock - 832 MHz
Shader Clock - 1747 MHz
Memory Clock - 4200 MHz
Memory Size - 1536MB GDDR5
Memory Bus - 384 bits
Output - DisplayPort / HDMI / DVI x 2
TDP - 260 W
Card Dimension - 305x127x45mm
DirectX 11 - Y
CUDA - Y
SLI - Y, 3-Way
PhysX - Y
PureVideo HD - Y
HDCP - Y
- World’s first 16 phase PWM on GTX 580.
- Independent, dedicated Memory power support.
- Copper MOS with 2x high current capacity.
- Proadlizer x 4 to optimized power supply.
- Twin Frozr III Thermal Design with 21C cooler & 5.5 dB quieter.
- Propeller Blade technology for 20% more airflow.
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation.
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.
- World’s first GTX 580 graphics card supporting voltage adjustment of GPU/Memory/PLL.
- Military Class II Components for longer product lifespan.
- LPL (Lightning Power Layer) for the stable power supply.
BUY NOW!
MSI R6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card
Stream Processors - 1536 Units
Core Clock - 920 MHz
Memory Clock - 5500 MHz
Memory Size - 2048MB GDDR5
Memory Bus - 256 bits
Output - Mini DisplayPort*2 / HDMI / DVI*2
TDP - 269 W
Card Dimension - 310x127x40mm
Form Factor - ATX
DirectX 11 - Y
OpenGL 4.0 - Y
CrossFireX - Y
Eyefinity - Y
AVIVO HD - Y
PowerPlay - Y
HDCP - Y
- World’s first 18 phase PWM on HD 6970.
- Independent Memory Power support.
- Proadlizer*4 to optimized power supply.
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter.
- Support voltage adjustment of GPU/Memory/VDDCI
BUY NOW!
For those that can't be bothered to click-thru to find the price...
MSI N580GTX Lightning £454.99 inc VAT
MSI ATI Radeon HD 6970 Lightning £339.98 inc VAT
I will be surprised if you don't hit 1000 Mhz Core with that cooler on the 6970 though...
There was a guy on xtremesystems that managed 1285 on LN2 with one of these boards I believe.
Overclock3D described the 580GTX Lightning as "A Sledgehammer in a whack-a-mole world" and awarded it with both their Gold award and their extreme performance award.
I know of at least one guy who topped had a 580 lightning at "1.1ghz running 3dmark 11 on air" using just the default afterburner voltage limits (i.e. not using any microswitches to unlock the extreme voltages)
KitGuru gave the 6970 their top Must Have award and waxed lyrical about the "engineering miracle" that is the new Twin Frozr III cooler.
oh & I had a play with the 6970 Lightning myself before sending it for review, 1000Mhz+ is a breeze, again, without unlocking the voltage limits. :eek:
Yes, quite and if you look you will see a 2Gb 6970 for £258:eek: But these cards are not in the same class as the above and are for real enthusiasts and epeen value.;)
Been waiting for the Lightning GTX 580 for a while....
I think the previous GTX 480 Lightning was a better looking card...pity MSI have done away with the backplate on the Lightning version :(
A GTX 580 of this spec and price should really have 3Gb Vram too
GTX 480 Lightning:
bit of topic but i've been seeing gtx 580's going for as low ad £340 inc p&p elsewhere.
why is this?
once MSI have had time to work with the GPU they develop their own cards with custom PCB's with more layers, more power phases, much higher quality components and as you can see, seriously uprated coolers.
it is possible to go the other way with cheaper PCB, cheaper memory, cheaper components & sometimes even cheaper coolers. i'd be surprised if I saw 580's getting this treatment :eek:
A quote from someone inside ASUS: Now that MSI doesn't really care about making a profit by selling the Lightning Series. They *paste* all kinds of expensive materials to build up their reputation, and we don't really have a good way to compete.
So it is best to buy these Lightning Series as soon as you see any, because it'd be hard to tell how long MSI can insist doing this!
well its working
MSI have really stepped up their game with their enthusiast line of products and they all seem pretty decent
when i do my next build i will seriously consider MSI for the mobo/GPU while 2 years ago i probably wouldn't
disappointing memory clock at kitguru on that 6970 core speed is good do.
but for that price you expect it to do or come out of the box at 1000/1500.
mine does 950/1450 without voltage increase and fan never goes above 38 % on stock cooling at full load temps 74 ~ 76
I think the 1.5GB vram on 580 lightning is most disappointing, otherwise I wouldn't have gone for 6950CF.
These lightning cards are the only cards on the market with a dedicated memory power phase. Before this, all graphics cards took the memory power from the PCI-E Slot, but the lightning uses to two extra PCI-E power pins (it uses 2x 8Pin rather than an 8 & a 6pin) to power a Proadlizer driven power phase just for the absolute maximum, stable memory power.
The memory voltage is tweakable via Afterburner and higher voltages unlockable via a micro-switch on the back.
In short, these cards were designed to allow LN2 coolers to break records without having to do their own voltmods, because we already did them for you! But thanks to the upgraded power and the best cooler on the market you don't need LN2 to push these cards well past the limits of any normal card.
