- 17 Jun 2010
- London
Nice unRaid build using this on AVForums if you Google Tim's 7.24TB "Tiddler" Unraid NAS.
(sure I can get down below 18w with some power cfg)Not even got the server yet and thinking of things i might need for it, including RAM and a graphics card. Just thinking might use VGA to connect it to the TV. Whats the res for VGA? im sure its as much as HDMI cable...
Anyone got Windows 2008 R2 on theirs?
Yep, I'm running Ws2008R2 SP1..
3Gb RAM (Added a crucial 2GB ECC stick for £26)
Via VGA, it does output 1600*1200 easily to my monitor.
I detailed my 'low power' setup in this post, Here
Loading configuration files.
Booting platform: embedded
Looking for configuration file: da0 ad4 da0
FATAL ERROR!
The device that contains the configuration file (config.xml) could not be found. FreeNAS cannot continue booting.
The operating system has halted.
Please press any key to reboot.
Thanks!UPDATE: The below is fixed, but I'll leave this post, in case others experience the same issue. (Solution at end.)
If this has come up already in this thread, please feel free to point me to the appropriate post number(s). I've tried to search, but the thread is rather long!
I've installed FreeNAS embedded version on a USB stick from the .img file, but I'm getting this error message:
A Google search suggested that I need to set the USB mass storage device to CHS mode. There was nothing similar in the BIOS, but I just upgraded to the latest version. Now there's "USB Mass Storage Device Configuration", which contains "Emulation Type", which can be set to Auto, Floppy, Forced FDD, Hard Disk, or CDROM.
I changed this from Auto to Hard Disk, but the error remains.
Can anyone offer assistance?Thanks!
UPDATE: I fixed this by simply using a different USB drive. I'm not sure what exactly made the difference, but the new stick is USB 2.0 (the old was 1.0); and the new stick is 1 GiB (the old one was 128 MiB (!)).
Hi,
I'm probably going to buy one of these servers on Monday but would like a bit of advice regarding additional hard disks and memory.
I would like 4 x 2TB disks and have been looking at:
Western Digital WD20EARS 2TB Hard Drive SATAII 64MB Cache - OEM Caviar Green
or:
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI)
Also I would like to upgrade the memory to 2 x 2GB - not bothered about ECC to be honest.
Does anyone have a working combination as this would be a sensible guide.
Thanks in advance.
...... IM SO EXCITED! Gonna be using this to run a couple of VMs (one Server 2008 and another XP Pro).Avoid the WD Greens for RAID systems, the F4 should be fine.
You can ebay the current stick and put most 2GB DDR3 1333MHz sticks in. I'm using Corsair, I know Crucial will also work fine.
Just bought one of these also, and only now have I come to this thread
Anyway a lot of pages reading later and it confirms what I've already found which is there is no bios option for a timed system start which is something I really wanted to be able to do.
I have found a way round it I think though. I'm pretty sure I saw the power restore option in the bios for always on or previous state. So I'm thinking one of those 24 hour timed mains sockets to turn the power on and off. Set the bios to always power on when the mains is restored and it will start up at say 9am every day, then set a script to shut windows down in the evening, and shortly after this time set the mains plug to kill the power.
I can't see any reason why that wouldn't work...?
