- 2 Dec 2006
Well, as some may know from my previous threads I have ordered a new pc and was unsure of the stability of my seasonic m12 600w psu. I emailed my local about trying to get them to test it under load for me as I have no guaranteed stable pc to try this on, nor do I wish to risk my new components doing it. Sadly they have not even bothered to reply. ( I did point out my concerns for them being cowboys). Anyways, onwards!
Now I'm not willing to go lower than 600w and am thinking I should probably aim for 750w really so that I may use it for future upgrades ( Though I said that about my sodding seasonic, what a waste). Shall be an overclocked SB pc with a 480gtx. The choices:
:EDIT:
New round up from post 12:
As I had mentioned to someone before on another thread when they suggested the XFX I dislike their RMA systems greatly. But they really are extreamly well made psu's and very well priced so I can't ignore them.
:EDIT:
Ok then new round up. The choice to make is no longer considering sli and instead just considering what will last for a GPU upgrade in 2-4 years. I don't plan on replacing this psu for another 5-6 years hopefully.
Also, do I need modular cables in the corsair 650d really? I'm thinking not.
1- Seasonic m12 620w - £79 (a bargain I think) Modular
2- XFX black edition 750w - £89 Modular
3- Corsair 750w TX ehanced edition - £86
4. Antec true power - £84 Semi-modular, might as well not be tbh.
5- XFX core edition 850w - £86
Stacking my options up it looks like it's between the two XFX's. Do I take 850w non modular and slightly lower quality, but not by much. Or the 750w modular and better quality. The 850w gives me a choice of sli later, but my graphics card is not best suited to it.
