Enable TRIM for any SSD on 10.6.7
18 Aug 2007
Liverpool
I didn't make this tool, and I don't know all the ins and outs. However, I did find this tool on MacRumors - it switches a single word of code in one of the chipset kexts to enable SSD TRIM for your own 3rd party SSD (basically by changing the drive ID from Apple-only to the ID of your own drive.
YMMV, and I haven't tried it myself (no SSD) but I thought some here might find it useful. Someone on MR made this tool to enable you to get TRIM working simply, no kext editing required. Worth a try - there are several reports of success on that forum.
Linky.
EDIT: If you want to know more, or to ask any questions, the thread is available here. As I said I'm only the messenger. :D
I've turned on the 'Yes I have TRIM' hex-edit - it's been doing the rounds for a bit.
What I don't know is whether I have TRIM support or not. Having it, and reporting it - well they're not quite the same things :)
Still, interesting hack.
Spotlight is reindexing after a reboot, don't know why.
The thread I linked offers 'evidence' that this does indeed work. For example, they did some 'jigging' with a file of a certain size and location in a Linux environment. Rebooted to OS X, deleted it, and moved back to Linux. Investigation of the hdd showed no file, but only zeroes. Or something. Apparently that demonstrates that TRIM is indeed fully functional rather than just saying 'Yes' for the sake of it.
As I said, I really don't understand the ins and outs, I just thought the tool was cool so I passed it on. :)
Be aware: I installed it and it utterly destroyed my SSD's performance.
Running firefox went from one bong to six, installs taking forever.
I've ran the remove and rebooted and I'm back to normal again....
2010 MPB6,2 and a Corsair F120 in case anyone is wondering.
Weird, this is the first issue I've heard of. :confused::(
Thought I should post a little update on my experience......
After I had the issues, and removed it, I tried to create a bootcamp partition for Windows 7. After about 15 minutes staring at the formatting screen, I received an error saying bootcamp couldn't partition the drive and I should back up my data and format my drive.
So, after backing up, formatting and reinstalling, I decided to try again with the Trim support.... Much better this time. No slowdowns, everything back to it's nippy self.
XBench Before:
Results 255.33
System Info
Xbench Version 1.3
System Version 10.6.7 (10J869)
Physical RAM 8192 MB
Model MacBookPro6,2
Drive Type Corsair CSSD-F120GB2
Disk Test 255.33
Sequential 158.42
Uncached Write 152.18 93.44 MB/sec [4K blocks]
Uncached Write 233.69 132.22 MB/sec [256K blocks]
Uncached Read 91.67 26.83 MB/sec [4K blocks]
Uncached Read 286.55 144.02 MB/sec [256K blocks]
Random 657.61
Uncached Write 456.62 48.34 MB/sec [4K blocks]
Uncached Write 458.79 146.87 MB/sec [256K blocks]
Uncached Read 2961.62 20.99 MB/sec [4K blocks]
Uncached Read 727.10 134.92 MB/sec [256K blocks]
XBench After:
Results 285.12
System Info
Xbench Version 1.3
Model MacBookPro6,2
Disk Test 285.12
Sequential 185.74
Uncached Write 273.69 168.04 MB/sec [4K blocks]
Uncached Write 233.89 132.33 MB/sec [256K blocks]
Uncached Read 92.64 27.11 MB/sec [4K blocks]
Uncached Read 355.66 178.75 MB/sec [256K blocks]
Random 613.22
Uncached Write 462.77 48.99 MB/sec [4K blocks]
Uncached Write 404.75 129.58 MB/sec [256K blocks]
Uncached Read 2952.83 20.92 MB/sec [4K blocks]
Uncached Read 644.04 119.51 MB/sec [256K blocks]
Wouldn't touch this myself.
Upside: Possible performance difference you likely won't notice.
Downside: God knows what.
Hopefully 10.7 brings proper universal TRIM support.
I applied this and it caused all sorts of slowdowns. Random beachballs and just stuttering performance in things like browsing. Was fine again after I removed it.
Conversely I've done it on my Air (Apple SSD), Mini (Crucial M225) and on my 2011 MBP (Crucial C300) and all have worked just fine.
Me, Fez and Feek are all using Vertex 2e and are fine so far it seems. ;)
Oi, I wasn't fine! I might try it once more as some people are suggesting that it worked when they tried it again but it caused all sorts of issues with my 120gb vertex 2e.
