- 10 Mar 2010
I'm going to be buying a computer and want it to 1) last a while 2) be able to run high-demanding games.
The main games I want it to run "well" on are: Battlefield 3 (specs here: http://enterbf3.com/battlefield-3-minimum-requirements.php), Empire Total War, Shogan 2 Total War, Crysis 2, ArmA 2, Just Cause 2 and Bad Company 2.
Bold are priorities.
My budget is £1000-ish. I'm happy to go over, but by not much; which is why I'm deciding between the two:
Computer 1
Custom built from OCUK:
Two questions from this:
- Is the i7 worth it? Or can I just get an i5?
- Is the make of RAM a good one - "RipJaw"?
Computer 2
Total Price: £1080
http://www.overclockers.co.uk/showproduct.php?prodid=FS-041-OP&groupid=43&catid=1961&subcat=
(No SLI, No SSD, OS: W7 Home)
There are three concerns:
1. It is specifically designed for Crysis 2? Is that a downside for the other games?
2. There is only 4gb of RAM - Is 6gb really needed over it?
3. I know next to nothing about overclocking, and this is overclocked. I've heard overclocking can cause some problems - or is at least the root to some problems.
Both are 3d, which is something I really want.
The reason that I'm doubting the first, is that it is quite a bit more expensive.
Any and all help is appreciated.
Computer 1
Case: Coolermaster CM690-II Advanced Case - Black
CPU: Intel Core i7-2600K 3.40GHz Quad Core Hyperthreading Processor
Cooler: Corsair Hydro H50-1 Watercooling Kit
Motherboard: Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard **B3 REVISION**
Memory: G.Skill Ripjaw X 8GB 1600MHz C9 Memory Kit
Graphics Card: OcUK GeForce GTX 570 1280MB GDDR5
Hard Drive: Seagate Barracuda 2TB SATA 6Gb/s HDD
PSU: Coolermaster Silent Pro Gold 1000w Power Supply
OS: Windows 7 Home Premium 64-Bit
Total price: £1,300
Computer 2
Case: Coolermaster HAF X Case
PSU: Corsair TX 750W (Is this a bit low?)
CPU: Intel Core i7 (THIS IS OVERCLOCKED AT 4.60GHz)
Motherboard: Asus P8p67 Intel P67 PRO
Cooler: Corsair H50 CPU Cooler
RAM: Corsair XMS3 4GB (2x2GB)
Hard Drive: WD 500GB
GPU: Nvidia GeForce GTX 550i
Total Price: £1080
