gigabyte 480 blue screen help
5 Jan 2004
yesterday got a 480 gtx and tried some games, did a benchmark of gta 4 max settings at 1080 and it was 55fps which was fine. Messed about with with crysis max setting for 10 min was fine and so was metro. Later that day i played team fortress 2 max settings got between 50 - 120 fps (mostly 60ish). After 20 min i got a blue screen of death. After my pc restarted i played again this time after about 2 hours it happened again (during which my gfx card temp never went over 75).
Any ideas?
my specs
q6600 oc'd to 3.05ghz
4 gig ram
pc power & cooling 610w psu
480 gtx with 266.58_desktop_win7_winvista_64bit_english_whql driver
windows pro x64
Also what would you recommend me to use to test my gfx card to make sure my psu can handle it and the temps are fine?
,thxs
Your psu is probably the cause as it's not powerful enough. You have an oc on your q6600 and the 480 will use an awful lot of juice too.
Which gigabyte one is it?
Loop Heaven benchmark and see if it's stable.
but it doesn't sound like a decent branded psu ?
what make is the psu.
also, what message do you get on the blue screen
right ran it, watched it once then benchmarked it and here are the results:
Powered by Unigine Engine
Heaven Benchmark v2.5 Basic
FPS:
34.3
Scores:
864
Min FPS:
24.2
Max FPS:
76.7
Hardware
Binary:
Windows 32bit Visual C++ 1600 Release Mar 1 2011
Operating system:
Windows 7 (build 7601, Service Pack 1) 64bit
CPU model:
Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPU flags:
3005MHz MMX SSE SSE2 SSE3 SSSE3 HTT
GPU model:
NVIDIA GeForce GTX 480 8.17.12.6658 1536Mb
Settings
Render:
direct3d11
Mode:
1920x1080 4xAA fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
16x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Tessellation:
normal
How many times should i loop it before i can be sure thats the temps and power are fine?
,thxs for the help so far
checked for abit ip35 pro xe p35 and its not there. I'm probly going to run heaven for 1 hour and if its fine after that, i'll chalk it up to a driver issue and try another one.
,thxs for the help
