Bit of a noob mistake by myself, I read wrong and used 5w40 instead of 5w30, since then, I dont know if another issue has come along at exactly the same time, but the car is having to work much harder when driving and its effecting mpg, even when your cruising on the m'way you have to keep touching the throttle as if you let go your speed will drop at a faster rate than normal.
Clutch down so I am "cruising" makes no difference, still the same speed rate drop.
Is this the oil do you think? If it is, I am going to get a 5ltr and a filter and do an oil change on the weekend.
