Leccy costs...
7 Jun 2003
Gloucestershire
Way back when the 5870 first came out i bought it due to being cheap to run due to low idle power usage....
Now im thinking of an upgrade but i don't want to suddenly start sucking up 10x more juice than my PC currently does at idle / non graphics intensive stuffs, so what does a 580 and 6970 compare to when it comes to idle power usage?
Also i'll be gaming at 2560x1440 (come on hazro 27" :D) so what would people recommend? I think i'm mainly aiming to be able to play battlefield 3 at max on that res, i can't think of any other games that would stress it quite as much that i'm looking forward to
Ahhhh i keep forgetting about that comparison tool!!! Cheers :D
Think i'll go for a 580, i've not used an nvidia card since the 8800GT days so it's about time, especially seeing as i've been swearing at the ATi drivers lately.
What do you think 110w would relate to in costs? considering that was the difference in furmark, and it'll only use that when im doing very intensive gaming, i guess it'll only work out at a couple of £ per year? Not sure why i'm worrying so much about it really :p
Last question: GTX580 any real point in the 3GB models over the 1.5GB ones?
What's wrong with the ATI drivers?
I'm not entirely sure, ever since they went to CCC2 i've just had no end of problems and it's just sort of put me off, i think i still prefer ATI but the 580 offered more to me than the 6970s did i think.
I can't pinpoint it either but i just feel more comfortable with NV
What seems to be stuck in my head lately is:
ATI - buggy drivers and the 6xxx series just doesn't feel like an upgrade
Nvidia - hot and sucks up the juice
That's the way my mind has recognised the two over the past 4 months, whether it's true or not is another matter altogether but it's hard to get myself out of that way of thinking. Fingers crossed i'm pleased with the choice i've made of a 580 :)
Mind, with the way certain games are ported these days (eg, Black Ops), I wish I'd kept 4870 1Gb and upgraded to i5. No matter how much I tweak, I cannot get GPU to produce more than 45% load and CPU is at 80% over all 4 cores.
Depending on the rest of your hardware, might be something to bear in mind Mr B :)
i7 860 and 8GB ram, i don't think i'll upgrade the cpu and motherboard until at least bulldozer or ivybridge minimum, starting to think i should have snuck in a cheeky vertex 3 SSD though and hoped the missus didn't notice :p
Not that it matters, but kinda on topic: I recently got a power usage plug from a supermarket (in there 'bulb' section) for the princely sum of £1. Nice LCD display telling me how many watts I'm using and KWH etc. Always wanted to know. Overclocked (but idle and running an x700pro) q6600 @ 3.4ghz was 215W from the wall.
Still off topic, but if you use Npower you can get a free meter off them, you are supposed to clamp it to your the meter tails(the cables between your DB and meter) but there is nothing stopping you using it on the kettle lead to your PC, this will give you usage and cost. :)
I got one of those Npower meters a couple of weeks back. Surprisingly nice unit for a freebie! I'm no electrical expert, but I don't think it will give a reading when attached to a regular power lead as you it will pick up the flow from both the live & neutral wires and they will effectively cancel each other out. Having said that, I've put mine on the main cable between the household meter & the fuse box, and it works very well there. I can check the power usage of my PC by subtracting the 'background' usage and get a pretty good idea of the actual power draw. My C2D 6600 at stock 2.4Ghz & HD5770 draw about 150 watts at idle & 270 watts at load.
Toastor
Nice idea, I hadn't considered doing that! Although for the sake of a pound I won't be swapping to NPower! (plus I believe this one give more accurate readings - I've used an 'Owl' house meter before)
Toastor
Yup you would have to split the live a neutral for it to work. It is quite interesting to watch what things are using!
Pretty much all new cards use hardly anything at idle, partly thanks to undervolting and underclocking which older cards didn't use.
I wouldn't really worry about it, to eek a few less watts out at idle means buying a slow card.
