My bad, I read the wrong line.You have quotes for male/female condoms, pretty sure the female ones are not available here anymore, and even so, they have always been notoriously bad! Its fair to put that figure to 85%.
Male & female condoms? I see no mention of that there - Implanon is the subdermal contraceptive implant in common use now, not the old-style dams.
Then again, the figures themselves aren't very well portrayed. Are you (not you, PhillyDee) measuring a condom's effectiveness only on the basis of resulting pregnancy, or including prevention of STDs too? If the former, are you considering a general standard of use or assuming perfect usage? If the latter, are you citing male to female transmission rates or female to male rates? Condoms are very effective against pregnancy if used correctly (most sources cite 98% success rates under ideal conditions), but not so much for STDs - risk of transmission of gonorrhoea, I seem to remember, from male to female when using a condom is only about 70% reduction.
Sex these days is like playing russian roulette with your todger.
Why are you embarrassed about getting laid?
Only teenagers get embarrassed about buying condoms.
You're embarrassed about getting condoms? Grow up and man up.![]()
When was the last time you had some action?!
Woah, manly-man-man alert! Surprised you guys don't post on OCUK alert us of your purchases
There is something fundamentally embarrassing about buying condoms because when I buy groceries, the 16 year old check out girl doesn't instantly think I'm going to ram my value pack of raw chicken on my bell.
To me, buying condoms says: Trying damn hardest to get laid with any old heifer - worried incase I catch the bad aids if and when it happens!![]()
If you're in a relationship with a 'clean' girl, a medical contraceptive(jag, pill etc) will be enough.
So, it would embarrass me! Haven't had to displeasure of buying them in a long time.
She's probably looking at the many cucumbers, courgettes and butternut squashes on the conveyor belt, rather than the chicken![]()
There are some seriously misinformed and/or ignorant ideas in here regarding safe-sex & contraception. No wonder std and unplanned pregnancy rates are high!
Contraceptive efficacy rates
Typical Use
Implanon: 99.95%
The Pill: 92%
Condoms: 85%
Withdrawl:73%
[TW]Fox;18782616 said:Hmmm, odd figures they. They suggest that if you take the pill there is a 1 in 10 chance you'll get pregnant. This is surely incorrect - most people on the pill
a) Have sex more than 10 times a year
b) Are not having any babies, let alone one a year
Does it include the chance of the girl 'forgetting to take the pill'?
You buy condoms????????????
I've had the same one for years, quick swill under the tap and it's good to go again.
Based on those stats (and my extraordinary and proven virility) I should have 1000s of children by now. I have just 2 thankfully.
Do you lend it to friends too?
Read it again. Contraceptive effecacy, therefore prevention of pregnancy. Typical use as opposed to perfect use, which for condoms is indeed 98%. Perfect use for the pill brings it up to 99.7%. Typical/perfect use for the implant is n/a as it ian't behaviour affected.
Cheaper in bulk off the net anyway.
...that you know of![]()
