Thankyou everyone who helped me build my computer Here it is Finished
If anyone has tried building inside this case they wouldn't be screaming "cable management"
I've done a few systems using this case and it's a nightmare, there is no room behind the mobo tray what so ever, the only place as mentioned is behind the hdd cage... and it's limited.
Good build for the first time, just get rid of those blue lights :p
nice one!
As iTek says, there is no room behind the mobo for cables on this case. Though you can get it looking quite good if you hide them behind the hdd cages.
Will need A LOT of cables ties:)
Nice work for a first build!
Those cathodes flashing would drive me bonkers in about 30 seconds, even if they were a proper colour like Orange. :)
You might want to review your fan orientation as it looks like you have the side as exhaust and the top fans seem to be intake. Typically you'd have front/side as intake and rear/top as exhaust. Just saying.
+1! Not bad at all OP - and good specs!
I like Orange ;)
Like it. The rear exhaust fan is missing :) but seriously, the 2 top fans will be pushing a lot of air out the top and much of the air replacing it will be pulled through the rear hole. Fine for the cpu, but not great for the rest of the components. I would suggest sticking another exhaust fan at the back, or covering the hole. At the very least, stick a filter on it. Oh, and keep the radiator off. :)
The cathodes look great!
