- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
We now have the range of accessories from Corsair to improve their range of chassis.
Corsair Graphite 600T Window Panel @ £19.99 inc VAT
This replacement side panel features a clear window so you can see all your hardware while the case is closed. As an added bonus, we’re including a mesh insert. Simply remove the screws that hold the window in place, add the mesh side panel, and mount up to four (4) 120mm fans (not included) to boost your cooling performance!
- Graphite colored 600T side panel with clear window
- Metal hexagon mesh insert with rubber fan mounts
- Quick Start Installation Guide
Only £19.99 inc VAT.
ORDER NOW
Corsair Obsidian 800D SATA 6GB/s Upgrade Kit @ £9.98 inc VAT
Upgrade your Obsidian Series 800D to SATA 6Gb/s speeds with this easy upgrade kit. Requires a Phillips screwdriver to install. For full SATA 6 Gb/s speeds, appropriate hardware is required, such as a compatible hard drive and SATA controller (not included).
- Replacement SATA PCB for 800D case
- Replacement cable harness with 90 degree power adapter
Only £9.98 inc VAT.
ORDER NOW
Corsair Obsidian 800D/700D Front USB3.0 Panel Upgrade Kit @ £12.98 inc VAT
Upgrade your Obsidian 800D or 700D to SuperSpeed USB 3.0 specifications with this easy upgrade kit. Requires a Phillips screwdriver and a motherboard or add-in card with rear USB 3.0 ports.
- USB 3.0 I/O panel for Obsidian Series 700D or 800D full-tower case
- USB 3.0 to USB 2.0 adapter cable
Only £12.98 inc VAT.
ORDER NOW
ORDER NOW
Only £9.98 inc VAT.
ORDER NOW
ORDER NOW
