We've had an additional 222 units since, but chances are they would have been part of that same production run, so we may have got them at different times but I would suspect they initially part of the same batch.
fair enough response
1) £200 is a lot money, my point was these were £350 - £400 originally, if I paid that I'd want it running as advertised, but at £200 if it meant it was unstable in a benchmark or needed a bit more voltage I'd just sort it myself.
2) There is a chance of failure with any product, this card is no different in that aspect, graphics cards normally have a 2-4% failure rate, these are in the 6-8% region which is above the norm. The SE car is the safer bet!
3) It does not mean the other 139 are faulty either!
4) The norm is 2-4%
I shall find out what Gigabyte actually use to test their cards because for gaming I suspect they are all fine bar the odd exception, running furmark is no doubt generating too much heat and I suspect Gigabyte maybe don't use that in their testing.
If you have fears then I suggest you go with the Asus or Gigabyte SE model, but for the money I'd get the SOC, its close to half price and is not far off GTX 580 performance and if you get a great runner, excellent, if in the odd programme it artifacts I'd simply give it a voltage bump to cure because the warranty will still stand with both OcUK and Gigabyte.
Gibbo can you confirm the voltage bump on the GPU and its effect on Warranty please ? as I read on Gigabyte forums that any voltage increase invalidates the warranty ?
question was posted re the 470 SOC - can't see how it would be any different ?
http://forum.giga-byte.co.uk/index.php/topic,2967.0.html
Sorry Gibbo, what was that about the 480's only going to go UP in price and nearly selling out?
But how can Gigabyte prove the voltage has been moved? They can't! As such warranty remains, if your hard coding the voltage into the BIOS then obviously yes that would void warranty because your re-flashing the BIOS on the card.
But if your just using software to adjust voltage no warranty won't be void and neither can Gigabyte prove you have done so.
Stick with the SE because you will probs be sending the SOC back for RMA
Extra annoyed now not only did i pay more money for the se card over the soc card the se card has come down 20 quid on this week only.
May not sound a lot but when u building a pc to a tight budget it is i could have put that 20 quid towards a better cpu cooler or got a couple of extra case fans
Oh well guess its my fault for not waiting a day or two.
Interested in buying one but the above is putting me off...
The Giga 480 SOC is great card.
I've not had a chance to OC it yet, but its solid & stable @ the stock SOC speeds.
It's a shame that some users are having problems
Temps definately not the issue with mine
Occt errors within seconds with gpu temp still under 70c
No difference even with case side off
