Well ... i know that there must have been lots of people making the same question ... amd vs nvidia.
So ... i sent my 590 back to the store and i need to spend the credit i have on cards ... since i'm using a 5850 from a friend on this computer ...
So, the cards will be underwater ... and i've always been a nvidia user ... but with all the buzz around the 590 i just felt tired of this "theater" and decided to make a change... and since i decided not going to opt for a dual gpu card ...
... i was thinking on getting 2 Sapphire 6970's and water cool them ...
But ... you know ... leaving our "comfort zone" is a pain in the a** and i'm having second thoughts about this since i've always been a Nvidia user... ( although i hate just using one side of the coin ... that's why i want to go AMD to see the other side ... only then i can say if it's worst ... better or just ... the same )
Do you think the 6970 CF is a good solution or should i go with the 570 SLi ?
I've been told that AMD drivers are much more stable now and that people just keep saying they're bad because of the "fanboy/flame wars" ...
That's why i needed your help ... for more input on this.
( i've been checking reviews, and although benchmarks like 3dmark and heaven are not on top, in games 6970 CF can, sometimes, breathe on 580's neck ...sometimes ... )
I'll be using a 1920x1200 monitor but upgrading for 2560 later in the year ( maybe ... )
System:
i7 920 @ 4.5Ghz ( HT On )
X58A-UD7
6Gb Kingston Hyperx 2000Cl8
System:
X58A-UD7
