- 7 Mar 2007
Hi all,
My computer restarts after a few minutes whenever I play a game (Sims 3, 007 Blood Stone, Batman: Arkham Asylum). This problem has coincided with the new GFX card being installed but I'm pretty sure its not a faulty card; i'm thinking maybe its power related?
I have a new Radeon 6950 with two 75W 6-pin connectors from my 500W PSU going in to it, as recommended on the AMD website.
I ran FurMark in stability test mode wth all other options set to default (Xtreme Burning mode off). The GPU temp gets to about 86 degrees then suddenly the computer shuts down for about 2 seconds then reboots itself. As it's going through the usual post screens I can hear the GPU fan doing its nut for a few seconds before it slows to normal speed.
AMD website recommends a 500W PSU minimum for this card and I have an Akasa PaxPower 500W as shown here (it was new in 2007 when purchased!")
http://www.overclockers.co.uk/showproduct.php?prodid=BG-039-AK&vat=1
I have also 4 internal SATA hard drives and a DVD writer installed. Obviously these are all using power but is this alone enough to cause reboots? Also tested with taking side of case off to see if that made a difference, upgrading/downgrading Catalyst drivers; all to no avail!
Please help as i've waited years for a decent GFX card to play new games on and now I can't play longer that 30 minutes before it reboots!
Cheers,
Paul
Cheers,
Paul
