Can these really not be refurbished?
DRZ
DRZ
2 Jun 2003
In the top 1%
Hi,
Took the alloys I plan to put on the mx-5 to a locally well regarded alloy wheel refurbishers today and was told that they cannot be done :( :confused:
The reason they gave for refusing them was that the lip between the rim and the centre would trap the sand from the shotblasting and would be impossible to remove, ruining the finish.
I've emailed a couple of other places just to see, but does anyone know if this can be done and/or who would take on a job like this?
Pics:
Cheers!
What's wrong with acid dipping them? :confused:
If the place doesn't do acid dips and only sand blasts, then its a fair point.
It might be a case that these cannot be refurbed by that place, not that they cannot be refurbed at all.
How you getting them done? 2 colours?
What wheels are they? I like the look of them for my 5... if I can't get some watanabes for a decent price :D
Mazdaspeed MS-01
Skeeter, I want the centres done in white with the rim polished.
The place said categorically that they couldn't be done at all (and suggested I found somewhere that would cut the centres out and weld them back in once refurbished! :Eek:), but yeah maybe they didn't know about acid dipping.
I thought you were supposed to bead blast rather than shot blast alloys anyway?
Try a different place.
as already said, try acid dipping or aqua blasting them?
Of course, if worse came to worse, you could always have them sandblasted and then have the gap filled?
Acid dipping isn't going to remove the pitting from all that corrosion. I can understand their reluctance to touch them, it seems like those wheel could have been purposely designed to trap grit and water etc.
