The best antivirus for a netbook running windows (Dell Duo)?
18 Mar 2010
We just got a Dell Duo, it has a 1.5GHz dual-core Intel Atom N550 processor and 2GB of DDR3 memory.
Like all Dells it came bundled with Mcafee. it is already starting to really **** me off. We have had the Duo for literally 1 day and I am already getting pop ups suggesting I renew my AV subscription, when the bundled licence is for at least a year.
I am presuming there is no logical reason not to get rid of Mcafee?
If so what should I replace it with? I am obviously looking for a AV that will be as light on resources as possible. I was thinking of MSE, would that be ok on a netbook?
It's poor on my netbook, I found that Comodo uses much less CPU due to it's stateful scanning. :)
It was poor in that it was a resource hog?
what do you mean by stateful scanning?
I should have added that the Duo is primarily for my wife. This means that I am looking for an AV that is as unobtrusive as possible. I was running Comodo on my desktop and my wife didnt like the constant pop ups/quarantine messages etc. MSE just seems to do its thing in the background.
From the comodo docs:
On Access - Provides the highest level of On Access Scanning and protection. Any file opened will be scanned before it is run and the threats are detected before they are getting a chance to be executed.
Stateful - Not only is Comodo Internet Security one of the most thorough and effective AV solutions available, it is also very fast. CIS employs a feature called Stateful File Inspection (tm) for real time virus scanning to minimize the effects of on-access scanning on the system performance. Selecting the ‘Stateful’ option means CIS scans only files that have not been scanned since the last virus update - greatly improving the speed, relevancy and effectiveness of the scanning.
If you're getting quarantine messages then you have a virus.
I have recently noticed MSE to be quite memory intensive on my 1gb netbook. It seems to use 60meg +. I haven't looking into alternatives yet but I will be when I get a chance. I'd probably avoid MSE.
EDIT - Its XP forgot to say
