2gb to 4gb
Depends on what you do with your system but generally the more RAM the better.
Just bear in mind with a 32bit OS it will only report and use about 3.5/3.4 gig of your 4 gig of RAM.
I think you would notice a difference, although it won't be massive. Probably the cheapest way of speeding things up a little.
I'm no expert with photoshop but I do know that some of the rendering processes will eat up a lot of RAM, so the more you have the better.
This guide should help you out.
thanks for the reply think i will order another 2gig and see if it improves, another thing overclocking the processor will that make any difference
Having a high processor speed will speed up any of the tasks you have to wait for, although by how much is dependant on what processor and how much it's overclocked. For Adobe Photoshop I doubt it will make a huge difference, although for something like video editing or converting a higher speed would help.
Yes, you definetely will.
I had to go down from 4GB to 2GB for a short while as one of my sticks died. I definitely noticed the difference, and you will to.
4gb is definitely the sweet spot for Windows 7. Anything less will slow it down, especially when you're using Photoshop - a lot of layers will eat your RAM and put everything else on the slow swap file.
I don't think you'd notice the difference between the 3.5gb and 4gb though that you'd get with 64-bit, but I'd recommend the OS upgrade anyway if it's in your budget. You'd be able to run Photoshop in x64 mode to use all your available memory too.
