Firstly, this is the spec that I'm thinking of building, I'll have the money to buy the parts on April 16th. I'm thinking of OC'ing the 2500k, but have never OC'd anything before:
OcUK Motherboard Bundle - Intel Core i5 2500K & Asus P8P67 Intel P67 Mainboard **B3 Revision** - £267.98
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) [OCZ3P1600C9ELV4GK] - £36.98
x 2 Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** [11162-15-20G] - £215.98 (already bought so I got them when they were cheap.)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) [ST3500418AS] - £29.99
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM - £14.99 Note: I know absolutely nothing about optical drives, is this a good choice?
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) - £17.99 Will this be good enough for if I want to OC the 2500k?
Coolermaster CM-690 II Lite Dominator Case - Black [RC-692-KKN3] - £58.98
OCZ StealthXStream 2 700W Power Supply [OCZ700SXS2] - 57.98 I also know nothing about PSU's, is this enough/a good choice?
Total - £700.87 (still got some left if you guys think I need to improve a part!)
So does this look good enough for high-end (ish) gaming? i.e. I want to play most games on a high setting, not really bothered if there's 1 or 2 higher end ones it won't run because I'll buy them for my PS3!
Also, are there are good guides for OC'ing on this website, or in fact any other site? As I've heard the 2500k is particularly good for overclocking and may aswell if my MoBo/Cooler can handle it.
I may also invest in an SSD in the near future as I've heard these really speed up a system, but can I just ask, in what way do they do this? Being a bit dim when it comes to current tech I don't understand how storage can speed up a PC!
Thanks
Thanks
