£200-300 Upgrade
7 Nov 2010
My machine needs an upgrade, it's mainly used for gaming and web browsing.
My Current Specs:
Processor:intel core duo E7300 @ 3.6Ghz
GPU:BFG Tech GTX 280
Mobo:JW-P45D2-ULTRA
Case:Antec 900
PSU:corsair 750w
Ram 4gig
Any suggestions?
thanks.
A SSD?
Blue-ray drive?
cant really suggest anything else, its not that bad a spec really.
A SSD?
Blue-ray drive?
+1
SSD is a really nice upgrade.
You may also want to consider upgrading the CPU to a quad core (you can get the Q6600 G0 for less than £80 these days) - as games are starting to make good use of more than two cores.
May I ask what monitor you are using?
you dont need a GPU upgrade for that size screen.
Your basketProduct Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail with FREE Shogun 2 Game £167.99
(£139.99) £167.99
(£139.99)
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £104.99
(£87.49) £104.99
(£87.49)
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £35.99
(£29.99) £35.99
(£29.99)
Sub Total : £257.47
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £53.39
Total : £320.36
maybe?
id get something like this, then sell your mobo, cpu, ram and gpu and depending on funds, 5850+?
stulids build does look pretty solid, ill give it a week and hopefully order the parts. Thanks for the replies and if I do get the money from selling the old parts an SDD seems apealing.
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail £124.79
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £59.98
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1333C8ELV4G £35.99
£232.15
